Results 1 to 10 of 10
    Member L...S...1's Avatar
    Jul 2009
    NOR*CAL
    2000 SS
    after changing fuel filter, something happened
    so i drove it down the street and i made a u turn and something snapped, popped and when i accelerate its like a scrapping noise right under the middle of the car. i checked the fuel filter and it was still on and everything. i dont know what it is but it only makes the noice when i touch the gas pedal......any help?!?!
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Check the trans mount and u-joints.
    Jul 2009
    NOR*CAL
    2000 SS
    ok thanks, and it kinda seems like the whole back of the car is sitting a little lower than it was before
    Jul 2009
    NOR*CAL
    2000 SS
    any idea how much u joints are???? i called my mechanic and he said it sounds like the u-joints.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Jack up the rear of the car, Put a block under the front tire to prevent it from rolling, put the tranny in neutral and turn the driveshaft and see if you can pinpoint the u joint.
    When you changed the fuel filter where did you jack it up at?
    U joints vary in price but are under 20 bucks, its the labor that will get ya.
    J
    Jul 2009
    NOR*CAL
    2000 SS
    i jacked it up by the rear tire on the drivers side for easy access. and everyhting was good till i made the u turn
    Oct 2009
    NorCal
    02 Z28
    wassup bro! sorry to hear about the maro, but as one of the guys said on top of me, i'd deff check out the u joint, tranny mount, driveshaft.
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Before You go throwing money the problem, get it back up in the air. Like said, turn the driveshaft. I have had my car completely up in the air on four Jack stands and ran the are looking for problems. Do this before you buy any parts because at this point you have no idea what the problem may be.
    Build in progress...
    Feb 2006
    2002 WS6
    U-joints won't make a scraping noise, more of a hollow thunk pink noise. A snap and scraping noise sounds like something mount related. Could be tranny mount or torque arm. Either way it needs to get back up in the air and be thoroughly checked. get it secured and give everything a once over and wiggle.
    11's "CLUB" SS SLP2's Avatar
    Silsbee, Tx
    Y2K Camero SS
    rear spring may have moved on its mount when car was jacked up, I would check springs and HPB
    just my .02's Johnny
    Y2K SS (SLP #239)
    Completly STOCK heads/bore/stroke/weight
    & NOTHING else ---is stock
    "NAW-NAW- just a Sunday goto meeting car, my best time is not in the 12's------- any more "
    ps: I am not soliticing work as I am retired
    >>>info on alignments
    http://www.jgruggles.com
  1. Question: Changing fuel filter
    By SS Camaro UK in forum General Help
    Last Post: 10-24-2012, 05:36 PM
  2. Changing my Fuel Rail setup
    By ls1camino in forum General Help
    Last Post: 09-29-2011, 04:23 PM
  3. kinked fuel line while changing fuel filter
    By krese in forum Firebird / WS6
    Last Post: 10-04-2010, 03:02 PM
  4. Question: Does a new fuel pump mean a new fuel filter too?
    By RaceMyLS1 in forum General Help
    Last Post: 02-16-2009, 11:11 PM
  5. fuel filter or fuel pump?
    By formulaon18s in forum General Help
    Last Post: 11-20-2007, 04:14 PM
