Results 1 to 20 of 26
Thread: Texas speed y pipe?
12-18-2009, 05:59 PM #1
Texas speed y pipe?
Anyone know anything about texas speed y pipes
12-18-2009, 06:31 PM #2
I think there is some talk about them in the header sticky
12-18-2009, 07:13 PM #3Awaiting Activation
- Jul 2006
- Tyler,Texas
Black on Black- 2001 Trans Am ws6
Almost the same thing as a pacesetter ORY but it is not flattened on the drivers side. It is made out of galvanized 3 inch pipe comes with install clamps (the crappy ones). Pretty good quality for the money I think. They hook up really good to pacesetter headers. From what I understand the newer design TSP y pipe has no floor rattle probs. Catted or ORY?
12-22-2009, 04:34 PM #4Member
- Dec 2007
- Minnesota
pewter- 2002 Tans am WS6 M6
I got the catted vesion in a box in my garage. Had bought a house a few months back so the car is just put to the side for now. What I have is a set of Jet_hot longtube headers and tXspeed catted Y waiting to go in, then a tune prob from Frost.
2002 Trans Am WS6 M6
12-23-2009, 02:23 AM #5Impounded
- Apr 2006
- park bench
- gmcheviac
It has a crappy merge to it. A Flowmaster merge in a custom y or welded into another would be better as far as power and rasp reduction
12-23-2009, 09:40 AM #6
mines only raspy over 3k rpm, and i like it (ory)
12-24-2009, 07:56 AM #7
This is incorrect.
The redesigned TSP Y-Pipes (both catted and ORY) include the Flowmaster Merge and are great flowing pieces. If I should ever have to replace my Jet Hot catted Y, I'll definitely be upgrading to TSP's catted version.
Here's a couple links to some additional info...
http://www.texas-speed.com/shop/item...d=189&catid=45
http://www.ls1tech.com/forums/genera...ed-y-pipe.html
1999 Firebird Formula
M6 Hurst-Billet Short-Throw|SLP Airlid, Smooth Bellows, Polished TB, & LS6 Intake|Jet Hot LTs, Catted Y-Pipe, & SLP Loudmouth|SLP Subframe Connectors
Spohn Adj. Torque Arm & LCAs
12-25-2009, 04:37 PM #8Impounded
- Apr 2006
- park bench
- gmcheviac
Did not know that. In the pic on their site it shows two pipes just welded together which sucks.
12-25-2009, 04:46 PM #9Impounded
- Apr 2006
- park bench
- gmcheviac
Looked at the new pics, defenitely as gradual or good looking as a flow merge, but Much better.
12-28-2009, 07:01 AM #10
i have one on my car now and it fits nice a close to the under side of the car i only have a bit of rasp for about 500-1000 rpm range around 3k or so but not that bad.
12-28-2009, 07:08 AM #11Junior Member
- Sep 2009
- OHIO
WHITE- 99 CAMARO SS
for money cany beat it mount up best to pacesetter and hooker , like mine and saved alot of money y pipe is a y pipe
12-28-2009, 11:18 AM #12Impounded
- Apr 2006
- park bench
- gmcheviac
a y-pipe in not just a y-pipe if you don't want it to sound like shit. With cheap headers it doesn't make a big power difference though
12-29-2009, 06:59 AM #13Junior Member
- Sep 2009
- OHIO
WHITE- 99 CAMARO SS
i know i have a tsp ory pacesetter and a slp lm and iam very happy with the way the car sounds , and with a texas speed m4 cam theres not to many cars that sound better , all depends on how you want your car to sound , i like loud ,
12-29-2009, 01:14 PM #14
I think you guys would be surprised. I stuck a pacesetter Y with their headers on my wifes car.
The Y junction was crap. I had to cut and rebend the driver side for floor clearance and while I was in there I noticed the hole for the Y-junction was only about 2 inches at best.
So I had a pair of 3 inch pipes merging together with about a 2 inch hole.
And I suspect most of the pacesetter Y's are this way, as I had another one the same way.
I ended up cutting that open and matching the hole size to the pipe diameter and rewelding. It's still not that great of a design, but I was shocked at the hole size. You would be much better off going to a Y-pipe with a good merge collector like something from Flowmaster.
12-29-2009, 06:34 PM #15Member
- May 2009
- Central Florida
red- 2000 Z28
12-30-2009, 08:47 AM #16Spaz is My Mentor
I have Pacesetter LT and TS&P ORY sounds great, tough ass hell, bottom out a couple of times. real easy to install. Clamps I agree are not that great, but do the job (seal up well).
Any questions PM me.
12-30-2009, 10:40 AM #17
Just got my TS&P Y pipe in, looks very good. Man it's HUGE! 3" all the way into the flowmaster type merge. Doing the install on Sat with a set of Ebay "Option" headers, I'll take pics to document. I will also have before and after go pro numbers, but it will be without a tune. Scheduled for a dyno pull on Jan 30, that should tell the tale of any gains.
12-30-2009, 04:05 PM #18
Yes you are right, it's different, in a good way. Texas Speed got it right.
As one post eluded to a "Y-pipe is a Y-pipe",,,,,but that's not really the case when you get down to specifics. Which is why I pointed out the issues with the pacesetter Y's that I've had.
Doing it all over again??? I would use a Texas Speed setup.
12-30-2009, 05:25 PM #19
Here's a pic of mine connected to the ebay headers, Install on Sat... Stay tuned.
12-30-2009, 07:33 PM #20
TSP Catted Y
I have the TSP catted Y and couldn't be happier. The pipe sounds and flows great. I have no rasp at any rpm. It takes a little time to "fine tune" how the pipes sit. I agree you need new clamps, I got AccuSeal band clamps. Fit and looks better.
2000 WS6 A4,Pacesetter LT,TSP catted Y, Magnaflow Catback, LS6 intake,Diablosport, Strano springs, Koni 4/3, UMI Adj Panhard, UMI LCA, Poly Motor and Tran mounts, Circle D 3B 3500 stall, Tuned by Frost
Question: texas speed?
By JoshuaGrooms83 in forum Internal EngineReplies: 5Last Post: 11-02-2010, 03:10 PM -
Texas Speed 3" Cat Y Pipe 100 miles
By y2kmaroonz in forum Parts For Sale / TradeReplies: 12Last Post: 05-01-2007, 03:30 AM -
texas-speed TD's?
By SLDWS6 in forum General HelpReplies: 1Last Post: 01-29-2007, 10:48 AM -
Texas Speed Y-Pipe
By tav8ws6 in forum External EngineReplies: 6Last Post: 11-28-2006, 01:01 PM -
Texas Speed 233/239 Cam?
By wesTXwitesnake05 in forum Internal EngineReplies: 0Last Post: 11-05-2006, 06:40 PM
