Thread: Things to look for in 3800
12-16-2009, 07:53 PM #1
Going to look at a 3800 firebird with a auto and 93k Miles, anyone want to give me a heads up on problems the car saw and what to look for? Thanks!
http://fayetteville.craigslist.org/cto/1510480893.html the addLast edited by 95camaroZNC; 12-16-2009 at 07:56 PM.
12-16-2009, 08:13 PM #2Senior Member
- Apr 2008
- Madison, WI
The number one problem is that its missing 2 cylinders...go get a V8.
Just kidding. The 3800 is a very reliable engine and you shouldn't have to many problems with it. Just check it over for leaks and maintenance upkeep (belts, hoses,plugs and wires,etc)
12-16-2009, 08:50 PM #3
thats what i thought. i have a 99 trans am this is for my gf i wanted her to have something reliable to drive.i knew the v3800 was pretty reliable.
12-16-2009, 10:50 PM #4
Keep an eye on your coolant level dexcool (if it has it) does'nt seem to like oxygen. Check for coolant leaks @ the front of the intake mani gasket. I run delco iridium plugs, and changed to 5w30 from the manufacter called for 10w30. 5w30 seems to allow the engine to run cooler say between 10-20 degrees cooler.. Other than that should be good 2 go.
12-17-2009, 04:15 PM #5Senior Member
- Mar 2009
- pompano beach florida
- 2002 Camaro Z/28 Pewter
Do your best to make sure its not eating or leaking coolant the 3800 is known for manifold gaskets and they are a royal pain to change.
12-17-2009, 05:16 PM #6
The Biggest problem is its in Fayetnam.. lol
Like said above just check over with a fine tooth comb. Just because hes asking 2300 doesnt mean you have to pay 2300...
3800 exhaust
By freaky57fast in forum External EngineReplies: 4Last Post: 05-24-2013, 01:23 PM -
Question: What does 3800 Perf. Pkg (Y87) mean?
By Superwoody in forum V6Replies: 16Last Post: 04-20-2010, 12:55 AM -
3800 stall?
By Ryans99LS1 in forum Automatic TransmissionReplies: 5Last Post: 11-12-2007, 02:55 PM -
3800 v6 tps mod
By apss in forum Parts For Sale / TradeReplies: 4Last Post: 01-06-2007, 03:53 PM
