Results 1 to 20 of 20
Thread: Window Motor
    Junior Member horns011's Avatar
    Sep 2009
    Orange, Texas
    2002 Z/28
    Angry Window Motor
    My driver side window is stuck down and it wont do anything.
    I have tried hitting on the door and slamming it but it still wont do anything.
    Is there anything else I can try to get it to come up one last time?
    Sometimes when the motor is dead, you can get it to inch its way up, may have to wait 5-10 mins between each inch of movement though. If its not moving up at all, you are probably SOL and just gonna have to bite the bullet and purchase a new window motor.
    Sep 2009
    Orange, Texas
    2002 Z/28
    Yeah its not moving at all
    I already talked to a dealership and they should have a motor before 2 tommorow.
    I was just hoping to not have to drive the volvo to school
    What price did the dealership quote you?
    O'Reilleys/Autozone/Advance sells the replacement motors for $50
    Sep 2009
    Orange, Texas
    2002 Z/28
    Not sure how much its gonna cost yet.
    My uncle is the service manager so it should be pretty fair
    They are doing the install too
    $.02 Queen OneSlowL36's Avatar
    Dec 2009
    Streamwood
    2000 Camaro
    I'd have them throw a regulator in there, usually thats the cause of the motor failing so often on these cars.
    Tulsa,OK
    Quick Silver
    2002 Z06
    The regulator does claim a lot of failures but the power distribution is also a BIG issue.
    Your express down module could have died. I would take the door panel off and try jumping 12v directly to the motor to make sure it is the motor.
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
    Member transamgirl89's Avatar
    Dec 2009
    Dacula, Georgia, United States
    2001 RS Camaro
    Quote Originally Posted by gnomee View Post
    And MAKE SURE when they put new regulators in they DON'T strip out those rivets or you're SOL. Those rivets are what keep the window aligned and if they're cracked or stripped out you might as well get a new door panel. Mine is like that on the driver side and no matter how many times I get the trim fixed it's still gonna leak water in there on occasion. So NEVER take it to an average mechanic like I did cause buddy am I paying for it now!
    Aug 2000
    Indy
    takes 40 minutes to switch out a motor with a beer break.
    04 C5 A4 Torch Red - sold
    2009 CTS4 Ice Black - sold
    2013 1500 Silverado Z71 - sold
    02 Z/28 M6 Onyx Black All Options - Sold
    2014 Caddy CTS4 - DD
    2016 Silverado 2500HD
    2020 Caddy XT6
    2020 2SS Vert
    '00 Z28 M6 NBM
    I piss excellence.
    Quote Originally Posted by OneSlowL36 View Post
    I agree....plus the windows on f-bodys are very big & heavy....alot of strain on those little motors over time. failure is to be expected.
    Dec 2009
    VA.
    BLACK
    2000 TRANSAM
    Window motor
    I've replaced one in both my ta's. If it started as going up & down slowly then you had to wait a few minutes or longer to get it to move the motor is bad. When you replace the motor use stainless steel bolts to put it back. Those rivots are a real pain. Get a friend to help you. Easier with two people
    Aug 2000
    Indy
    They make a nut riveter as well. Instead of a regular rivet it puts a threaded nut on the far side WITHOUT taking the panel off. Then next time it is real easy.
    Jun 2006
    somewhere over the pond
    black / black
    '91 Z28 / '10 SS
    So i was lucky yesterday that I was able to close my window. The window stopped half the way up, I had to wait 20-30 seconds and it moved all the way up.
    So its time for a new motor
    Tulsa,OK
    Quick Silver
    2002 Z06
    Check our website out www.autotrix.net... It might not be!
    Junior Member sharber's Avatar
    Hixson,TN
    Red/Black
    1998 Z28 T-top 6spd
    my old 95 camaro locked up two inches from closing. i took the window motor out and tried to lube it and hooked it back up to power but not in the door. it was locked up.
    i just had to buy a new window motor. don't buy from car part store. i got mine off the internet for like 40 bucks versus like 150 at the part store...it works fine. had to grind out rivets to remove from the lift and find new bolts and nuts to secure it.
    Hixson,TN
    Red/Black
    1998 Z28 T-top 6spd
    if the fix kit runs directly to your battery does that mean that the window may be rolled down while ignition off???
    if so i don't want that. all you would have to do is stick a hanger in the window and press the button a viola..you are in my car... no good if i am right.
    Tulsa,OK
    Quick Silver
    2002 Z06
    Quote Originally Posted by sharber View Post
    No that is not the case.
    We use relays to take the signal from the switch and redirect power from the batter to the window motor.
    There is no power to the switches when the ignition is off so the windows will not work.
    The windows will only work when they worked before. With ignition on or after ignition off before doors are opened. If your radio works the windows will work, if not, the windows will not work.
    Hope that clear it up..
    Jun 2006
    black / black
    '91 Z28 / '10 SS
    I'm just wondering why one day it looks like the window won't move and the other days it works perfect again...
    Tulsa,OK
    Quick Silver
    2002 Z06
    Most likely you're seeing a difference in temperature. Also it depends what you are doing, if you roll it down and go somewhere then roll it up.. It will roll up a lot faster than if you rolled it down to spit your gum and rolled it back up immediatly.
    Junior Member Armani Camaro's Avatar
    NY
    1999,Camaro z28
    take the door panel and do it manual after that replace the motor its like 35 $ new
  1. Window Motor
    By new2dgame in forum General Help
    Last Post: 06-22-2010, 12:34 AM
  2. need help with window motor
    By 01pewterZ in forum General Help
    Last Post: 12-17-2007, 11:10 PM
  3. Window Motor
    By NewLS1 in forum General Help
    Last Post: 12-17-2007, 03:53 PM
  4. Window Motor Mod??
    By CamaroFan71 in forum General Help
    Last Post: 10-12-2006, 07:36 PM
