Results 1 to 3 of 3
    Apr 2009
    Palm Desert, CA
    97 3.8L Firebird 5 Speed
    replacing the Stock unit
    Do you need to take apart the dash to take out the original Delco deck?, mine works some of the time but I hate when it turns off randomly. I want to replace it but is it hard? Car is a 1997 V6 3.8 5-speed Firebird if it matters
    Dawson, IL
    2000 Trans Am
    sounds like it could be the same issue as here: http://www.ls1.com/forums/showthread.php?t=127398
    Tulsa,OK
    Quick Silver
    2002 Z06
    No replacing the head unit is VERY easy.
    That grey plastic trim peice around the radio and A/C controls just pulls off. There is just a clip in the middle on the left and right. Just pull from the center, it may seem stuck but it comes out.
    Then the stereo can be removed with the two bolts holding it in.
    When you get a replacment head unit, get the wiring harness that will just plug into your factory wiring. You will have to connect the new stereo to that harness but then it will just plug in instead of you hacking apart the factory plug.
    I usually just go with crutchfield personally but best buy will also have the harness. I'm not sure if Walmart will.
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
  1. Question: Replacing factory head unit w new touchscreen
    By SSNAKEATER23 in forum Stereo and Electronics
    Last Post: 02-16-2011, 08:46 PM
  2. Question: replacing stock monsoon head unit w/ alpine
    By tgriffin47 in forum Stereo and Electronics
    Last Post: 05-06-2009, 10:07 PM
  3. Replacing stock heads
    By kbLS179 in forum Internal Engine
    Last Post: 08-16-2008, 09:55 AM
  4. Replacing the factory unit
    By silplu83 in forum Stereo and Electronics
    Last Post: 06-02-2008, 02:52 PM
  5. Stock Head Unit System or install custom head unit?
    By ibh182 in forum Stereo and Electronics
    Last Post: 06-16-2007, 09:43 AM
