Results 1 to 10 of 10
    Member Speed_kills_WS6's Avatar
    Feb 2008
    Anderson, SC
    2002 TA WS6 M6
    4.10's installed...Park Brake?
    I just got my new rear put in with 4.10's. Took me a little time, but got her done. When I get in to take a spin for the first time, the damn park brake light won't go off. What's the deal? Haven't got to really feel the gears yet, its raining out and my car just spun thru the first three gears, lol.
    Bragg NC
    Met. Sunset Orange
    01 SS
    The switch for the parking brake is in the console below the actual parking brake handle.
    J
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    The switch is at the base of your handle. Its a very simple, grounded switch. Its probably just unpluged and grounding against something.
    If you were to unplug that switch's wire ( blue in color IIRC ) and grounded it, it would pop the brake light on the dash. Pull that center console.
    Build in progress...
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Do you have traction control?
    Feb 2008
    Anderson, SC
    2002 TA WS6 M6
    Yes, I do have traction control. I'll check the switch out.
    Feb 2006
    Orange County, NY
    always dirty
    Check that you didn't smack up a sensor when you removed the axles.
    Feb 2008
    Anderson, SC
    2002 TA WS6 M6
    didnt remove the axles, put a complete different rear in the car. switch turns out ok.
    Feb 2006
    Orange County, NY
    always dirty
    Two things I can think of. If you put a 3 channel rear in it will usually trip the abs light. Other one is there should be a pressure switch somewhere near the master. If there is low brake pressure, say when a line goes or there is little fluid in, it will illuminate the brake light.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    the red brake warning light can come on for 2 reasons. The parking brake is on or
    there is low brake fluid level in the master cylinder
    Feb 2008
    Anderson, SC
    2002 TA WS6 M6
    You know what? I bled the rear brakes after switching my calipers over to the new rear. I was rushed and never put any fluid back in the reservoir. Checking that now.
  1. Park Brake Cable Dust Boot Sets!
    By sjgreen6 in forum Parts For Sale / Trade
    Last Post: 10-12-2014, 03:50 PM
  2. Corvette Brake Rotors - Give Me A Brake
    By Ed Blown Vert in forum Corvette
    Last Post: 09-17-2010, 03:39 PM
  3. Camaro Ebay LED 3rd Brake Light Installed
    By The Guz in forum Appearance Section
    Last Post: 08-05-2010, 06:04 PM
  4. installed new weiend intake. brake boost
    By apeshitls1 in forum General Help
    Last Post: 06-07-2010, 07:08 AM
  5. Replies: 0
    Last Post: 11-30-2007, 06:00 PM
