Results 1 to 16 of 16
Thread: missing out.
    Member 2000redcamaro's Avatar
    Jan 2008
    garland, texas
    00 z28 m6
    missing out.
    just wanted to see if anyone could help me before i have to take my z to the shop. not sure what is causing the misssing out. every once in a while my car will start missing out. it will hardly go and then all of a sudden it clears out and fucking takes off. last time i drove it it started this crap and i got pulled over by a cop couse my tires starting spinning. i had the same problem aroung march or april. i thought it was my plugs so i tried to change them but soon reliazed that i did not have the paitience and i keep breaking the dam plugs on the rt side so i took my car to LG and they said i needed pluge and wires. after they changed them ir ran great and not im having the same issues. i just want to see if anyone might know if its something else or do i just need to put it back in the shop.
    any help would be great thanks.
    LSwut tep98ws6's Avatar
    Jun 2009
    Saint Louis, MO
    Arctic White & Black
    '98 WS6 M6 - SWAPTIME!
    is it surging? or misfiring? i was a little confused reading it.
    Jan 2008
    garland, texas
    00 z28 m6
    its runs like it is misfirning and then is surges. kinda like riding a 2 stroke dirt bike befor it hits the power band
    Jun 2009
    Saint Louis, MO
    ahhh... did you check out your throttle body at all to see if it's sticking any?
    Jan 2008
    garland, texas
    00 z28 m6
    yes. im not sure if my mass air meter is going out, i cleaned it and put it back in the car and it ran ok 4 a while and then it starts this crap again. sometimes its only does it for a few seconds and then runs ok and other times it does it while driving in town but stops while on the hwy. its kinda pissing me off. i dont want to have to put it in the shop but i might have to
    Jun 2009
    Saint Louis, MO
    Quote Originally Posted by 2000redcamaro View Post
    ... do you have a screen on your MAF? otherwise, did you check the MAF for continuity?
    Jan 2008
    garland, texas
    00 z28 m6
    yes i have a screen, i just cleaned it off with brake cleaner even though it was not dirty. and not i did not check the continuty
    Jun 2009
    Saint Louis, MO
    ooo brake clean? you didn't get it on any connections did you? for future reference, they do make MAF cleaner which isn't as harsh as brake clean.
    check out the continuity, you may find your problem.
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    Any spark plugs in particular that were fouled? If it fixed the problem temporarily it sounds like a cylinder might be going.
    Jan 2008
    garland, texas
    00 z28 m6
    well i just went and drove it for about 2 hrs and it is running fine. no misfirning. i dont know what the hell is causing this but it is getting on my nerves.
    402 Guru 402 Guru's Avatar
    Jan 2008
    las vegas
    02 Trans Am T-tops M6
    make sure all of your plugs are on the plug tight. best what to do it is with a wrench push them on snug in 1 motion stright not back and forth if you co back and forth u can break the plug but now when is the lst time u got your spark plugs changed? are u using nitrous ? do u hang in high rpm's l8ly ? you could just have a cloged injector or the fuel filter $9( it just takes 1 fill up of bad gas or contaminated gas to do this and clog you fuel filter/injectors ) is clogged and driving seems to get it all slushed up and flowing properly clean out you fuel system get a fuel filter and a lucas fuel system cleaner runs $6 at any auto parts store .when is the lst time u changed the fuel filter ? how many miles on the camaro ?
    Tulsa,OK
    Quick Silver
    2002 Z06
    Yeah changing the fuel filter is a good idea..
    Do you have headers? A melted O/2 wire or Spark plug wire intermitantly (spelling) shorting out can cause weird issues like this.
    Just a weird option... I accidently left a screw driver under the hood of my 96. Wife told me the car was runnig weird, I tested it and sure enough it was doing exactly this kind of thing. Damn screwdriver was in between the batter shorting the positive to the A/C condenser. I'm SO lucky nothing bad happend.
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
    Member zeetwentyeight's Avatar
    Aug 2009
    A, A
    1998 Camaro Z28
    service engine soon light on at all?
    NeW YoRk
    2001 ws6
    try cleaning the maf and changing the fuel filter
    Junior Member SPDYGON's Avatar
    GEORGIA
    RED
    2001 CAMARO ss
    what about the throttle position sensor ? ohm it out
    Jan 2008
    garland, texas
    00 z28 m6
    thanks for all the help yall. i try some of your ideas and hope it takes care of the issue. again thanks
  1. need help??? ls1 missing
    By ozmossis in forum LT1
    Last Post: 11-08-2010, 07:58 PM
  2. Missing Cat
    Last Post: 09-02-2010, 02:18 AM
  3. Missing ?
    By 97txaggie in forum General Help
    Last Post: 06-18-2010, 05:36 PM
  4. Missing Something?????
    By predator506 in forum Camaro / SS
    Last Post: 11-07-2007, 02:10 PM
  5. What am I missing?
    By slims00ls1z28 in forum Request and Feedback
    Last Post: 07-01-2007, 11:04 AM
