Thread: C-5 oil change
    Nov 2008
    harrisburg pa.
    02 vette vert
    C-5 oil change
    what's the proper fill level with an oem ac filter? the 6.5 qt. fill leaves the level on the dipstick about 1/2 qt. low. what's right, 6.5 qt., or fill it to full on the stick?
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I would go with the 6.5 qts. Yours holds 6.5? I thought all LS1 V8s held 5.5-6 qts.
    Military Muscle :usa: MYSCZ06's Avatar
    Columbia,SC
    Millienum Yellow
    2003 Corvette Z06
    fill too full on stick. The amount of oil needed can vary slightly, but generally it's around 6.5 qts. Some owners put up to 7 qts in, but you need to check how much your vette needs. I'd start with 6.5 qts, then check the level after letting the engine run for a minute or two and then off for a few minutes (to allow the oil to drain back into the oil pan).
    As for the filter, I personally prefer Mobil1.
    Nov 2008
    harrisburg pa.
    02 vette vert
    it' in the oil pan design. these have a wing type pan.
    Quote Originally Posted by MYSCZ06 View Post
    that's normal procedure, after all is said and done sitting level with 6.5 qt. in it shows mid-way between add and full on the stick. i didn't know if that's common and i should stick to 6.5, or put 7 in to bring it to full on the stick. too much oil is bad.
    either way, something isn't right, either the stick is off, or the 6.5 is just to start, with the final top off decided by the stick.
    most anything else i service shows full at whatever the book calls for.
    i guess my biggest concern is not putting too much oil in. there could be variations in the dipstick:tube not pressed in the whole way, something not right at the handle end, which could cause a false low reading.
  1. Name Change
    By Crimson Sin in forum Request and Feedback
    Last Post: 12-05-2008, 03:34 PM
  2. Name Change Please
    By Sweet Chops in forum Request and Feedback
    Last Post: 12-05-2008, 11:03 AM
  3. name change
    By blacksupersport in forum Request and Feedback
    Last Post: 11-29-2008, 12:37 PM
  4. Handling change w/ tire change
    By hotdog453 in forum Wheels and Tires
    Last Post: 06-17-2008, 07:17 PM
  5. Name change please
    By LETHALxLS1 in forum Request and Feedback
    Last Post: 06-11-2007, 11:33 AM
