Results 1 to 20 of 29
Thread: intercooler help!?!??
12-05-2009, 09:39 AM #1
Anyone have any good recommendations on an intercooler?I want to put one on my car(2000 SS)but not sure what type to get,location,and that sort of thing.Any help or advice would be much appreciated!!
12-05-2009, 02:26 PM #2Impounded
- Nov 2009
- Pa
- 2000 firechicken
what mods do you have?
12-05-2009, 05:58 PM #3
Procharger?
12-06-2009, 08:26 AM #4
Mostly all-stock engine!I have a worked-over Powerdyne blower making 6.7lbs of boost @ 5800rpm.I have 1-3/4" long tubes and all 3" exhaust.My tuner says I Really need an intercooler,not exactly sure what to get!!
12-06-2009, 12:37 PM #5
mine is mounted just behind the bumper cover. I dont have the inner core anymore. If you want to keep yours try a set of procharger ic's. They are fairly small, although they do require more piping.
12-07-2009, 12:04 PM #6
Thanks,I'll give that some consideration!!I wonder if a camaro has as much room as a firebird does!?!?How did U route the piping?
12-07-2009, 12:08 PM #7
the pipes go in on the pass side bottom and out driverside bottom
12-07-2009, 06:30 PM #8
Hmmm,got any pics u could post? Sounds like a good way to route them tho!
12-07-2009, 06:43 PM #9
Why not just get a meth kit?
12-08-2009, 08:25 AM #10
IMO, Procharger's twins are not very effictive, had them originally. I have a front mount now 25 degrees cooler intake charge that the twins. Meth was another 20 degrees + detonationm suppression. I'll post up some pics of the IC later today when I get home from work.
12-08-2009, 02:54 PM #11
Here's a pic of what my front mount set up looks like uner the nose ofthe car. I purchasd all the parts seperately & put it togter. EPP has a kit now that wil cost roughly the same as what I spent with far less fabrication work to do yourself. The twins are mounted flat under the car & therefore get a lot less air flow than a front mount.
12-08-2009, 03:08 PM #12
Hey guys,thanks for all the good info!!Hey Mark98ss,what all did u have to remove to fit that big of an intercooler in there!??and thanks for the pics!!Looks awesome!!!
12-08-2009, 03:30 PM #13
Thanks, the IC is hanging from what's left of the front impact bar, also removed the styrofoam on to of & in front of the impact bar. That IC is 24x12x4, pretty standard size actually.
12-08-2009, 03:32 PM #14
P.S.
Also cut out the grill area in the bumper cover asyou can see in my sig pic above & installed on of these along with the meth pump:
(jk)
12-08-2009, 04:10 PM #15
12-08-2009, 04:47 PM #16
Sweet Mark!!!now where do I get a Flux Capacitor!?!?!?That would solve all of my problems!!!
P.S. What is EPP?
Thanks
12-09-2009, 01:38 AM #17
12-09-2009, 01:39 AM #18
12-09-2009, 01:29 PM #19
About how much should I expect to spend on a similiar intercooler setup?
Thanks again!! I'm just trying to maximize the set-up I already have,I'm not trying to get too crazy,ya know!?!?!
12-09-2009, 05:27 PM #20
I have maybe $800 iparts in mine, mostley home brew, this is my IC from EPP $299
Wanted: Intercooler
By SmokinSS in forum Parts Wanted / TradeReplies: 1Last Post: 08-27-2019, 06:03 AM -
WTB: Intercooler
By SmokinSS in forum Parts Wanted / TradeReplies: 0Last Post: 07-12-2009, 06:02 AM -
Question: Trans am and intercooler.
By spaz1 in forum Forced InductionReplies: 4Last Post: 05-30-2008, 09:49 AM -
Intercooler?
By jcirulli in forum LT1Replies: 6Last Post: 08-14-2006, 02:23 PM -
Intercooler
By AF1Bird in forum Forced InductionReplies: 6Last Post: 05-03-2006, 05:11 PM
