Results 1 to 20 of 72
Thread: Royal purple
12-04-2009, 05:28 PM #1
Royal purple
I just purchased royal purple motor oil this will be the first time ive used it. But my car has 137000 miles on it and i was told that if i switch to that oil and havin such high milage i would blow some seals, or it just wouldnt be good for my car. An my car is the 1999 Firebird V6 3800 series 2, is this true and if so what oil would be the best instead. Does the same thing apply to transmission fluid for my car and it is an automatic with minor slippage. Thank you
12-04-2009, 06:23 PM #2
The majority on here would probably run straight piss in their car before RP -- not being mean, just letting you know how this crowd feels. The fear that you have expressed is from the original synthetics which were found to cause leaks. Those oils lacked seal swelling agents that have long since been added. Best oils to run probably include Amsoil, Penzoil Platinum, and "German" Castrol (which I haven't figured out yet myself). There is a great oil thread on here somewhere that goes into some detail on oil selection.
12-04-2009, 06:35 PM #3
I believe its a bull, that if you change oils you'll cause leaks.
12-04-2009, 06:49 PM #4
i switched to full synthetic Pennzoil at 180,000 i have no leaks or issues what so ever
12-04-2009, 06:56 PM #5
i wouldnt put RP in my car ever. RP is crap...most people on this site will agree with me
12-04-2009, 07:32 PM #6
I use Pennzoil Platinum.
12-04-2009, 08:05 PM #7
I would'nt put RP in my lawn mower.. Or any other engine for that matter..
12-04-2009, 08:22 PM #8
Schaeffers oil is the best in my opinion
Ashes to ashes and dust to dust, if it wasn't for fords our tools would rust
12-04-2009, 08:29 PM #9
12-04-2009, 08:34 PM #10
rp is crap. sarge is the man to talk to about oil here is a link its long but you get a lot from it about oil.
can http://www.ls1.com/forums/showthread.php?t=1299Last edited by Sarge; 12-07-2009 at 03:24 PM.
12-04-2009, 09:06 PM #11
12-06-2009, 12:23 AM #12
Seal issues...
Pajeff02 is correct about seal swelling agents. That said, you shouldn’t have any issues with the switch. In fact I switched from conventional petroleum based motor oil to Amsoil with a car that had 130,000-miles and have had no issues with leaks.
However, there is one leak causing phenomena that can come from any sort of lubricant switch on vehicles with higher mileage. It’s been said that over time and/or a combination of improper maintenance, some motor oils can contribute to deposit build-up. Such build-ups around seals can have a secondary sealing affect when aging seals begin to lose their ability to seal. When another competing chemistry from a differing motor oil’s additive package is introduced to the said higher mileage engine, the old oil deposits can begin to be removed by the new oils additive package. This in turn allows the failing seal to be exposed to the internal oil flow as designed at which point a leak can occur.
Further, this could be more of an issue with synthetic motor oils as they can have better cleansing abilities depending upon how they are formulated.
This condition could actually contribute to the myth that synthetic motor oils cause leaks when in reality it was a faulty seal to begin with and the oil was simply doing its job.
But again, as with my personal experience and witnessed by many others, the switch to synthetic is generally a non-issue.
12-06-2009, 01:06 AM #13
just ask sarge......he swears by royal purple
u can switch to synthetic but u have to use synthetic for now on......thats the only "problem" you will have if you change to synthetic.....
i run penzoil platinum personally.....
12-06-2009, 11:16 AM #14
Royal purple was designed from scratch for the aluminum blocks with iron liners.I have been running it in my muscle car since day 1 it came out and it contains all the additives formulated specifically for are engines some people are just haters and would rather buy foreign oil . I like to keep the money in america where are people need the money
Last edited by 402 Guru; 12-06-2009 at 12:25 PM. Reason: hhhhhhhaaaaaatttteeeeerrrrrrssssss
12-06-2009, 11:27 AM #15
12-06-2009, 11:30 AM #16
12-06-2009, 12:09 PM #17
Dude don't be a hater let me put my hater blockers on there we go you're gone. What was that you like buying foreign products so you can help obama make are country in an even more of a recession you have to think about our kids not your own selfish needs. if everybody bought usa made products then we would have more jobs and the best oils in the world are formulated from scratch from racing applications to daily drivers it all depends on your application and what they put in it . If you cant take the heat trans am 1973 then stay outta the kitchen
12-06-2009, 12:17 PM #18Turgid Member
- Jun 2009
- Hollywood, Florida by way of Da' Burgh
Impulse Blurr- 2004 GTO
And not very well at that. On several fronts. I think it's a doppleganger.
I'm not a big fan of Royal Purple. Presently I'm running Pennzoil platinum and when that is over I'm going Amsoil. I'm already running Amsoil in my differential. My mileage is only 48k but I don't think switching to synthetic should create a problem for you. CompSyn's breakdown was pretty comprehensive. I would change it at 5k the first 2 or 3 times for it is bound to strip a lot of contamination from the inside of your engine. That is to say it should get dirty quick. And I'm not a "troll" regardless of what the ..... below me says.
Internet Troll:In Internet slang, a troll is someone who posts controversial, inflammatory, extraneous, or off-topic messages in an online community, such as an online discussion forum, chat room or blog, with the primary intent of provoking other users into an emotional response[1] or of otherwise disrupting normal on-topic discussion.[2] Says the "thing" that brought politics into an oil discussion. I am done, end of discussion.Last edited by Goat-E; 12-06-2009 at 01:00 PM.
12-06-2009, 12:23 PM #19
Troll you wonder why u have infractions .This is for comments on Royal purple not for Trolling goate
12-06-2009, 12:46 PM #20
wow what a troll you had 4 words up thereand then you post this long drawn out letter then edit everything you sayed im happy we have moderators that give out infracions to people that deserve them. That is a great example of a Troll.. anyways Royal purple is Awesome and as long as it keeps money in america im for it amsoil is a great product but royal purple was designed for are engines in particular
2010 Royal Purple Giveaway - Royal Shop Talk
By Ed Blown Vert in forum Camaro / SSReplies: 1Last Post: 06-10-2010, 03:33 AM -
Royal Purple
By Mr. Luos in forum Almost Anything GoesReplies: 62Last Post: 08-01-2008, 10:48 AM -
royal purple vs pp
By slpcamaro in forum General HelpReplies: 32Last Post: 07-24-2008, 04:59 AM -
Royal Purple
By MavrickCJH in forum Internal EngineReplies: 12Last Post: 10-16-2006, 04:59 AM -
Where to buy Royal Purple?
By Blown Interceptor in forum Western MembersReplies: 11Last Post: 06-19-2006, 06:58 PM
