Results 1 to 20 of 27
Thread: Cheap HP Upgrade?
12-04-2009, 01:08 PM #1
Cheap HP Upgrade?
I have a 2000 Trans Am. I got 3.73 gears, high flow converters, and a catback system from Magnaflow, and I got a tune on the motor. Other than the tune the motor and tranny are stock. I run a consistent 13.6 all day. I want to get in the mid 12's without a lot of money. Does anyone have any suggestions on how to do that.
12-04-2009, 02:14 PM #2Awaiting Activation
- Oct 2007
- NC
SOM- 1998 T.A.
Well if you are an A4 car a stall will be your biggest bang for the buck. Otherwise I would do headers. But neither one of these will get you 12.5 from where you are.....
12-04-2009, 03:02 PM #3
How much money do you have to throw at your car? What do you define "cheap" as?
12-05-2009, 02:38 AM #4
Cheap or not it's time for Headers
A La Fois Prochain , Bon
12-05-2009, 03:34 AM #5
you should be going faster than that with 3.73's. I have the factory gears and am also an a4 and run close to that bone stock.
12-05-2009, 02:19 PM #6Impounded
- Nov 2009
- Pa
- 2000 firechicken
converter if you have a a4.... you will be in the 12's with a nice torque converter
12-05-2009, 03:06 PM #7
he should be close to that now. SFC's, full exhaust and 3.73's and slicks on factory wheels put my friend at 13.1 after the 4,000 stall(too high in opinion) he went 12.6
12-05-2009, 09:10 PM #8
Cheap HP upgrade?
What I mean by cheap is less than $1,000. I don't want to spend that kind of money and only gain .300 on my quarter mile time.
12-05-2009, 09:12 PM #9
Best bang for under 1K is headers. You're going to have to dump more than 1k to get to where you want to be I'm afraid.
12-05-2009, 09:30 PM #10
12-05-2009, 09:40 PM #11Junior Member
- Nov 2005
- warren, mi
my 2000 ta ws6 a4 is stock except for a slp y pipe with electric cutouts and a full aftermarket stereo and i run 13.6 or better at the track, something doesn't seem right here
12-05-2009, 09:46 PM #12Senior Member
- Oct 2008
- Coral Springs, Fl
OP what was your 60'?
12-06-2009, 04:24 AM #13
Not everyone is going to run the same at the track. Several factors will come into play. What was the weather like when he ran? What was the condition of the track? Did he use street tires? What is the DA? How much track experience does he have?
Like Tater said, the 60' time will tell everything. I don't think that 13.6 is THAT out of whack, but he should probably be running a little quicker.
Bottom line is he still isn't going to be in the mid 12's with what he is looking to spend.
I guess everyone's point could be that if he should be running 13.2 (for sake of argument) and he is running 13.6 (.4 slower) if he wants to run 12.5 he would almost need an 11 sec car to do so
12-06-2009, 07:29 AM #14
12-06-2009, 11:31 AM #15
12-08-2009, 08:25 AM #16Awaiting Activation
- Oct 2009
- Austin
yeah headerse is what i would go with
12-08-2009, 10:05 AM #17
Like 35th said the DA has a HUGE effect on ET.
Running at a track at higher altitude is going to be slower than a track closer to sea level in the exact same car.
Do headers and y-pipe and also if you can find out your DA someone on here can tell you if you are running slow or close to right on for your area.
12-09-2009, 06:37 AM #18Senior Member
- Jun 2008
- Rochester, NY Rochesterracing.com
- 2000 Camaro B4C
free mods already done?
12-09-2009, 08:34 AM #19
12-09-2009, 11:39 AM #20Awaiting Activation
- Oct 2007
- NC
SOM- 1998 T.A.
Yank SS TC = $725
Transgo shift kit = $70-$80
Labor = $500 (unless you can do it).
^^^^^^best bang for buck^^^^^^ Should be worth .5
cheap brake upgrade?
By mark21742 in forum GTOReplies: 7Last Post: 06-04-2011, 11:07 AM -
JET Performance Chip for sale!! 99 Camaro/Firebird LS1 automatic CHEAP CHEAP CHEAP!!
By J4moflo in forum Camaro / SSReplies: 0Last Post: 02-17-2008, 08:39 PM -
SLP Rear suspension upgrade, CHEAP!
By blackSS01 in forum Parts For Sale / TradeReplies: 9Last Post: 11-27-2007, 11:44 AM -
Simple Upgrade Solutions - Oem Upgrade 2003 Bmw X5
By Ed Blown Vert in forum Stereo and ElectronicsReplies: 0Last Post: 11-16-2006, 08:18 AM -
Big screen 51 inch HD Rear projection TV F/S local only in Philadelphia Cheap Cheap
By Hurley711 in forum General ClassifiedsReplies: 14Last Post: 08-30-2005, 07:02 PM
Headers and an ORY are you best bet
