Results 1 to 18 of 18
    2002 Arctic White T/A Ws6islife's Avatar
    Sep 2009
    Houston , Texas
    Metallic Pewter
    2002 SLP Firehawk
    oil leaks :/ please help
    I have a minor oil leak, its not tranny oil or im not sure..here are a couple pictures maybe some of you guys can help me out.
    Sep 2009
    Houston , Texas
    Metallic Pewter
    2002 SLP Firehawk
    by the way the pictures are of places where i saw droplets of oil colleting ready to drip.
    Member TA98's Avatar
    Mar 2009
    Maryland
    rear main..?
    that looks like the back of the car under the trunk... could be either your rear leaking or the drive shaft could be flinging oil there from another leak spot...
    Sep 2009
    Houston , Texas
    Metallic Pewter
    2002 SLP Firehawk
    no its not even near the rear its like right behind the oil pan, but its not the tranny cus the smell and color isnt tranny oil..
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Could be the rear main. One of the things I like to do is clean it all off. Take the car and put all 4 corners on jack stands on level ground and get under there with a creeper, degreaser, couple rags, brushes and clean it real good and wash off the a little water. Drive the car for a day. Now put it back on stands and see if you can find were it is comming from.
    Sometimes oil leaks can come from the front of the car or motor and the air passing under the car sweeps them back and then it finds a collection point and it forms drops that drip. Cleaning it will help you find out were it is really comming from. At this point to you can clean almost the entire underside as well makes getting under the car in the future a little less messy.
    Sep 2009
    Houston , Texas
    Metallic Pewter
    2002 SLP Firehawk
    good advice will do tommorow when i dont work..thanks alot so if its the rear main what should i do?
    Sep 2009
    Houston , Texas
    Metallic Pewter
    2002 SLP Firehawk
    damn just found out rear main is expensive :S bummer
    Sep 2009
    Houston , Texas
    Metallic Pewter
    2002 SLP Firehawk
    i wont jump to conclusions tho i will clean it up check and see what it trully is
    Mar 2009
    Maryland
    how much $
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    yea I had a leaky power steering cap that would push out some fluid and it ended up under the car and would drip on the exhaust every now and then back by the passenger floor board. It threw me for a while because the entire right side under the car was wet with fluid that smelled like trans fluid. cleaned up the bottom and the engine bay and 2 days later I saw a wet spot next to the reservoir.
    Sep 2009
    Houston , Texas
    Metallic Pewter
    2002 SLP Firehawk
    so yep it is the rear main gasket, i put my car up on jackstands was hoping for the best i turned the car on i started cleaning and then as i was cleaning the bottom of the tranny right where it meets the engine i noticed i kept cleaning and cleaning but it kept comming out i was like F*** lemme make sure, so i got a flashlight adn i wiped again and i saw it seeping through. bad news is that its pretty expensive to fix it not to get the gasket but on the bright side i found the leak *SIGH* ha im so relieved
    I have a small weep that accumulates in exactly the same spot as is pictured. It never drips on the floor, just enough to make that area look wet. If it ever does go, that will be my excuse for swapping out the heads, cam and converter.
    Sep 2009
    Houston , Texas
    Metallic Pewter
    2002 SLP Firehawk
    at first i was like damn it not the rear main but then i thought about it and was glad it wasnt head gaskets or something cracked so its good it was just the gasket to the rear main
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Did you check the oil sending unit and valve covers? Could be leaking down to there.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Clean the area real good with brake cleaner, Pull the inspection plates and use a flashlight to inspect. Could be, sending unit, oil pan, rear main. Its oil i would say from the color.
    J
    Sep 2009
    Houston , Texas
    Metallic Pewter
    2002 SLP Firehawk
    yea i checked them im pretty sure its the rear main..anybody suggest me fixing it? never took a tranny off but have a friend that does all his own work i mean i know how to do cams, and headers, and pulleys adn pumps and intake heads and what not but have never messed with a tranny..
    Bragg NC
    Met. Sunset Orange
    01 SS
    Its not bad at all, Once you remove the linkages, Driveshaft, and cooler lines, Unbolt the bellhousing and T/c if auto and undo the four bolts on the cross member and slide it back and down and the tranny should slide down, Dont forget the dipstick tube.
    I tranny jack makes life easier but a simple floor jack will also work.
    If you want i can give you a quick write up later today. Drop me a pm with your email...
    Do it yourself and save some serious Cash or take it to the shop and get charged an arm and a leg... maybe even a first born child.
    J
  1. Help: 98 Z28 leaks
    By JacobLS1 in forum General Help
    Last Post: 03-27-2012, 07:54 PM
  2. Leaks
    By oharam in forum Camaro / SS
    Last Post: 02-28-2011, 03:48 PM
  3. Help: Hatch leaks
    By 2000dreambird in forum General Help
    Last Post: 03-15-2010, 03:30 PM
  4. Leaks
    By bb4ninja in forum General Help
    Last Post: 02-10-2009, 10:30 AM
  5. how do i fix the leaks
    By CHiCKeN08 in forum Firebird / WS6
    Last Post: 08-18-2007, 03:21 PM
