Results 1 to 2 of 2
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Exclamation Corvette Distributor Rebuild - Rebuilding The Tach
    Corvette Distributor Rebuild - Rebuilding The Tach-Drive Distributor
    We restore performance in a Delco-Remy "window cap" distributorThe postwar General Motors OHV V-8s were difficult to tune. Ignition distributors mounted at the firewall end of the engine, and the breaker points and condenser were difficult to replace. In the late '40s and 1950s, professionals turned to distributor strobe machines and worked on the ignition with the distributor removed from the engine.inline_mediumwraptextrightDelco-Remy's window cap distributor was an engineering breakthrough. A unique breaker point design allows point adjustment through the cap's window. This can be done with the engine running, a timesaving, fine tuning approach. Another innovation of the window cap distributor is its spring hook hold-downs.31426782/techarticles/corp_1001_corvette_distributor_rebuildcorp_1001_01 +corvette_distributor_rebuild+.jpgTrue
    Photo Gallery: Corvette Distributor Rebuild - How To Restore Performance In A Tach-Drive Distributor - Corvette Fever Magazine
    More...
    Have one of these in our '74 equipped with an Accel dual point setup. Added a 90 degree fitting to straighten out the cable run as things are kind of tight. Good information!
  1. Help with 2004 LS1 5.7 Corvette Rebuild
    By V8Torrent in forum Internal Engine
    Last Post: 11-24-2011, 02:54 AM
  2. Corvette Carburetor Rebuild - Carter AFB Blueprint
    By Ed Blown Vert in forum Corvette
    Last Post: 03-09-2010, 04:17 PM
  3. Corvette Suspension Rebuild - The C4 Suspension Ad
    Last Post: 12-15-2009, 10:30 AM
  4. ls1 rebuild /turbo rebuilding
    By xzaero0 in forum Forced Induction
    Last Post: 07-19-2007, 09:18 PM
  5. MSD Distributor
    By 1993RedLt1 in forum LT1
    Last Post: 04-30-2007, 09:44 AM
