Results 1 to 20 of 237
Thread: My Build Thread!
12-02-2009, 12:34 PM #1LSwut
- Jun 2009
- Saint Louis, MO
Arctic White & Black- '98 WS6 M6 - SWAPTIME!
My Build Thread!
Going from basically stock (SLP lid, MSD wires, Flowmaster cat back, o2 simulators) to completely rebuilding (Ported 243 heads (300cfm intake/200cfm exhaust - HELL YES), ported LS6 oil pump, LS6 intake, 231/231 .621/.621 112* cam, ported throttle body (607cfm), stock valves & seals, stock rockers, LS7 lifters, hardened push rods, Comp springs, titanium locks/retainers, adjustable timing set, LS7 clutch & throwout bearing, honing cylinder walls, connecting rod bolts, LS1 piston rings, crank/cam bearings, new freeze plugs and removing EGR & AIR
I will be updating this as I go with pictures and the fun things I find along the way...
Here we go!
Beginning;
It took six hours to drop the engine & transmission ... most of the time spent trying to remove bolts that were rusty and corroded. Along the way, the EGR & AIR was thrown to the side
After that, smooth sailing ... until we got to the last bolt on the cradle ... somehow, there was a bright orange balloon wrapped around the bolt, WTF (I didn't take a picture tho)
As we were lifting the car off the engine and double checking everything was removed before going higher
All of this will be disassembled tonight and cleaned up
... I will add more tonight
12-03-2009, 05:00 AM #2
looks like fun!
12-03-2009, 06:08 AM #3LSwut
- Jun 2009
- Saint Louis, MO
Last night, I disassembled the engine and found LOTS of interesting things ... such as a ton of sludge, burnt valves and a BLOWN HEADGASKET ... so needless to say, I'm pretty f-ing happy I'm doing this now
ALSO! I broke that stupid oil PSI sensor like EVERYONE told me not to do because I yanked on the head and it just tore it right off
the giant mess i made
tonight, cleaning up the block, ball honing the cylinder walls, polishing the crank and installing new bearings =)Last edited by tep98ws6; 12-03-2009 at 07:36 AM.
12-03-2009, 07:06 AM #4COTM July '09
- Jun 2008
- Annapolis, MD
BLK/BLK w/CGM Stripes- 2010 Camaro 2SS/M6
Fun time!
12-03-2009, 07:13 AM #5
Looks like your doing a good job tep! Sounds like she will be running good a strong when its done.
12-03-2009, 07:15 AM #6LSwut
- Jun 2009
- Saint Louis, MO
thank you!
im really excited and really hoping it will be something i can be 400% proud of =)
12-03-2009, 07:46 AM #7your parts guy!!!
- cleveland ohio
trans am 00 ws6- 1998 camaro ss vert
that cam is huge. you stay with stock cubes?
12-03-2009, 07:53 AM #8
12-03-2009, 08:21 AM #9
12-03-2009, 08:22 AM #10
With the power this should put down I would have went with a different/ better clutch then the LS7.
12-03-2009, 08:26 AM #11
Nice work! I think I mentioned this before -- make damn sure you get all the coolant out of your bolt holes before re-installing the heads. Will the car be going on the dyno when completed?
12-03-2009, 08:32 AM #12
12-03-2009, 12:04 PM #13
you know your gunna have to take me for a ride when you get it done!! and then start on mine!
12-03-2009, 12:06 PM #14
12-03-2009, 01:55 PM #15
While you have the engine and trans out, I would seriously think about installing a Tick remote bleeder. It will make Flushing/bleeding a breeze later down the road. We all know that these Fbody hydraulics want/need to be flushed yearly at least.
http://www.ls1.com/forums/showthread.php?t=124254370 CI - Twin 6766 Turbo - Jakes stage 5 4L80E - MWC 9" - Holley Dominator
Build in progress...
12-03-2009, 10:23 PM #16LSwut
- Jun 2009
- Saint Louis, MO
Tonight I tore the engine the rest of the way down and only found one odd thing ... one original spark plug wedged in between my motor mount and the block
har har
shit looks like wood grain
all clean!
my intake after two coats of white, still taped off and waiting for clear =)
reassembly starts monday after ball hone,
12-03-2009, 10:31 PM #17
Damn girl, you're making some really good progress.
12-03-2009, 10:34 PM #18
Dam! Nice job!! Reminds of doing my little 305 at school too
12-03-2009, 10:37 PM #19LSwut
- Jun 2009
- Saint Louis, MO
http://lswut.blogspot.com/
My Build Thread
http://www.ls1.com/forums/showthread.php?t=126838
my cam is just a little big and my car is a little loud
12-03-2009, 10:41 PM #20
My 98 Z28 build thread...
By ChevyZ76 in forum Member's RidesReplies: 15Last Post: 08-02-2014, 01:24 PM -
Another Build Thread
By kenro23 in forum Member's RidesReplies: 77Last Post: 06-12-2014, 09:15 AM -
LQ4 Turbo Build Thread
By My00Z28 in forum Forced InductionReplies: 89Last Post: 08-28-2013, 12:41 PM -
Build Thread 2.0
By tep98ws6 in forum Internal EngineReplies: 23Last Post: 08-07-2013, 06:56 AM -
Members build thread
By 10spokess in forum Request and FeedbackReplies: 14Last Post: 07-21-2011, 07:21 AM
No thats awesome.
