Results 1 to 15 of 15
Thread: Weight?
    Nov 2009
    Santa Ana, CA
    Weight?
    Does the 2000 convertible SS weigh less then the hard top?
    Thanks
    JP
    Senior Member
    Mar 2009
    Milwaukee
    Arctic White, red/gray
    1997 Corvette, 92 Typhoon
    Quote Originally Posted by fixtheglitch View Post
    Thanks
    JP
    NO, vert is heavier
    Jenks/Tulsa
    Light Pewter Metallic
    y2k 8-cylinder catfish
    The verts are the heaviest of the three options.
    Junior Member SPDYGON's Avatar
    GEORGIA
    RED
    2001 CAMARO ss
    verts are about 200 pounds heavy
    Arizona
    Not 200 lbs. difference, not even close.
    They are actually closer in weight than most people realize. For an accurate weight on any particular car you really just need to hit the scales with it. I've seen them all over the place.
    For instance I have both a T-top SS and a convertable SS
    My vert comes in at 3,620 lbs. without me in it.
    My T-top weighs 3,560 lbs. without me in it.
    Both had just over 1/2 tank of gas. As you can see the vert only gives up about 60 lbs. Not even enough to get excited about. And my vert is an automatic too which some say adds more weight. My T-top is a 6 speed. But those 6 speeds are not featherweights either.
    Otherwise they are optioned identical.
    Couple friends of mine had T-top cars that were actually heavier than my convertable. So you just can't speculate without hitting the scales.
    Nov 2009
    Santa Ana, CA
    Thanks Guys
    GEORGIA
    RED
    2001 CAMARO ss
    my numders are from the tags on the doors of 01 camaros SS
    my t-top came in at 3650 with full tank and myself in on the scales , one on each wheel
    my friend vert door tag say 3850
    Pittsburgh
    2008 Hummer H3
    Subscribed..
    Senior Member
    Mar 2009
    Milwaukee
    It also has to do with options and which f-body you have aswell.
    But a fully optioned SS/ws6 vert is gonna be a good 80-120lbs more than a full optioned SS/ws6 t-top if both use the same tranny. The only vert car iever saw on a scale was a nicely options z28 vert, i cant for the life of me remember the numbers past this 37XX.
    Member Maro SS's Avatar
    Mar 2009
    Oldbridge
    VEHICLE BUILD
    Merchandising Model : 1FP87 -2001 CAMARO Z28 2-DOOR COUPE Gross Vehicle Weight Rating : 1924 kg (4242 lb)
    that was from the vehicle inquiry sticky.. i always thought that was the weight of my vehcile right there 4242 lbs... my friend told me no way that was too heavy... i guess hes right lol
    whats that number above refering to?
    Senior Member
    Mar 2009
    Milwaukee
    Quote Originally Posted by Maro SS View Post
    VEHICLE BUILD
    Gross vehicle weight rating is the weight of your car and as much stuff as it shoudl be loaded with. Meaning your car with you and fuel and cargo should never weigh more than 4242 or you are exceeding the gross weight limit.
    That guy thearborbarber's Avatar
    SoDak
    White over Red
    1991 Suburban
    That is a max weight the vehicle can weigh with the car, passengers and baggage.
    Mar 2009
    Oldbridge
    hmmm ok good to know i guess.. i weigh but 125 lbs anways so
    Arizona
    Quote Originally Posted by SPDYGON View Post
    Ya my convertable door tag is something close to 4,000 lbs. as well. But on the scales it was 3,620 lbs. Door tags aren't even close and in most cases will list either gross weights or weights without fluids as the car would be shipped on a carrier.
    Arizona
    My wifes previous 97 Z28 vert with a 6 speed only weighed 3,520 lbs. It is a solid 100 lbs. lighter than my 02 SS vert, with an aluminum block and fiberglass hood verses a cast iron LT1 and steel hood.
    Both were loaded with all the electronic goodies. These cars are just all over the place as far as weight goes. I also can't explain why a pair of T-top cars were heavier than my 02 SS convertable on the same day.
  1. Weight
    By Alex18 in forum Wheels and Tires
    Last Post: 04-19-2010, 08:11 AM
  2. So much for the camaro weight.. New Mustang Weight
    By Aetos in forum Almost Anything Goes
    Last Post: 12-01-2009, 06:24 PM
  3. So much for the camaro weight.. New Mustang Weight
    Last Post: 12-01-2009, 08:07 AM
  4. rim weight
    By third_shift|studios in forum Wheels and Tires
    Last Post: 05-26-2007, 04:32 AM
  5. Keep the weight or weight reduction?
    By JwMonE99 in forum V6
    Last Post: 10-16-2006, 08:24 AM
