Results 1 to 18 of 18
Thread: Question About Nitto NT555R's
02-14-2006, 07:20 PM #1
I recently got these DR's for the track but haven't had a chance to run them yet. My question is, do these tires need just a quick spin the clean them off like regular street tires, or is it better to go ahead and roast them a little bit to heat them up?
EDIT: I've heard both ways, I just wanted yous guyses input.
02-14-2006, 07:34 PM #2
02-14-2006, 07:43 PM #3Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Heat them up for a few seconds.
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
02-14-2006, 07:46 PM #4Adios and vaya con dios
- Nov 2005
- Gadsden, AL
Victory Red- 2002 Corvette Z06
I know they are to tire to have on Lightnings, know that doesnt help too much but has to say something about the tire
02-15-2006, 06:51 AM #5
sweet. thanks for the help ed. now if I can just get rid of this wheelhop...
02-16-2006, 06:24 AM #6Senior Member
- Sep 2005
- New York, NY
Collectors Edition Yellow- 2002 Pontiac Trans AM WS6
Just put my nittos on yesterday!!!! I have the street drag radials 315/35/17VR and WITHOUT a heat up and 411RWHP and 403RWTQ i grabbed like a SOB dumping the clutch at 3K....... I do have all supporting suspension mods but before the tires i broke loose of my street tires like they were bald... Now i cant even break loose of these!!! I love em!!!!
Hope it helps!!!
Joe Ballz
Bulletproof Performance
2002 Trans AM WS6 M6 Collectors Edition
LSX 427 F-1R Procharged Build Underway
Estimated Finish Date: Summer 2012-2013
02-16-2006, 07:58 AM #7Junior Member
- Nov 2005
- florida
Red- 1998 z28 a4
sorry to hijack but what suspension mods are you running?
Originally Posted by NeeD4SpeeD
02-16-2006, 10:54 PM #8Senior Member
- Sep 2005
- New York, NY
I'm runnin a BMR adj TA, BMR LCA's, BMR Adj Pan Hard, BMR Weld IN SFC, and a Spoan STB.... Thoes are my suspension mods included with the tires and they make a nice traction combo!!!
Originally Posted by NxLS1496
02-17-2006, 09:02 AM #9
I use the 16 inch Nitto 555R's and have to heat them up pretty good. When smoke is rolling off them I wait about 3 seconds and pull up to the light. If I don't make sure they are hot, I get crap traction and catches and lets go...horrible on rear end.. I run them at 18psi at the track and 31 psi on the street. The only suspension things I have changed is boxed lca's, boxed sfc's and Bilstien shocks.
02-17-2006, 09:59 PM #10Senior Member
- Sep 2005
- New York, NY
How much Hp you runnin man??? Cuz i have had nothing but traction even with very very short heat up process....
02-28-2006, 04:56 PM #11
One more question, should I use the waterbox or no? I've heard no on plain street tires, and I've never used it.
Another thing (this is going to sound like a stupid question) but when you use the waterbox, you're just supposed to give them a quick spin in the water to coat the whole tire, then pull out of the box for the full burnout, right?
02-28-2006, 08:19 PM #12Adios and vaya con dios
- Nov 2005
- Gadsden, AL
i always back the rears into it, and the pull just in front and start spinning
03-01-2006, 08:32 AM #13
yea i use the 16 inch nittos, run them at 12PSI, burn out in waterbox, hold on for 5 seconds or so... thought i was getting wheel spin but turns out i have 2.73s and its just slow... cant wait for 3.73s and ill see how good these nittos really are
03-01-2006, 08:42 AM #14
I use the 555rIIs, they're for auto cross/drag, but help me stick real good on the track or in the corners with a little warm up time to make them stick. Once I see smoke they're ready.
03-01-2006, 07:02 PM #15Senior Member
- Sep 2005
- New York, NY
I thought it was against NHRA regulations to run through the waterbox with anything other then full race slicks??? If it's not then i KNOW the officals will hate you for dragging water down the track because of the treads in the tires... Just from what i've heard...
Originally Posted by jmhvenom
03-01-2006, 07:53 PM #16
I've never used the water box before. Just spun them dry...
03-04-2006, 01:39 PM #17Senior Member
- Sep 2005
- New York, NY
Originally Posted by jimbo98z
03-04-2006, 05:57 PM #18
They let the people with drag radials line up in the slicks only lanes too, I pull up to the edge of the water and get them hot, then pull forward. Without the hot burnout traction is terrible. I like the nitto's, just have to make sure they are hot and they hook good. I only have right around 350 rwhp, but I also have the 3400 stall and it breaks tires loose easy. I am going to put some LCA relocation brackets on and it should launch great. I am just at the point now, that I need some little things to hook good. My 16 inch tires are only 245, so may be since they are not as wide traction suffers a little. On hot days when track is 100+ they stick like glue, cooler days is when I have the problems.
315 NT555's or NT555R's
By My00Z28 in forum Wheels and TiresReplies: 19Last Post: 11-02-2011, 05:58 PM -
Like new Nitto NT555r Drag Radials
By jetaws6 in forum Parts For Sale / TradeReplies: 2Last Post: 10-14-2011, 08:10 AM -
Nitto NT555R 315/35:17 $200
By 01RaptorTA in forum Parts For Sale / TradeReplies: 13Last Post: 04-16-2007, 02:06 PM -
WTB 1 Nitto NT555R 275/40/17
By The95Z in forum Parts Wanted / TradeReplies: 1Last Post: 10-02-2006, 09:56 PM -
I need 1 275/40/17 nitto nt555r sa,tx area
By The95Z in forum Parts Wanted / TradeReplies: 1Last Post: 09-09-2006, 12:22 PM
