Results 1 to 3 of 3
12-01-2009, 12:05 PM #1
Antenna not going all the way up or down
Has anyone had the problem of the antenna not going all the way up or down? Do I need to replace just the antenna mast or do i need the whole motor?
12-01-2009, 01:38 PM #2Senior Member
- Feb 2006
- Orange County, NY
You can replace just the mast. First I would try some lube to see if it helps.
12-01-2009, 05:32 PM #3Member
- Tulsa,OK
Quick Silver- 2002 Z06
The mast probably just got bent.
I did have one do that and it just fixed itself after about 6 months..
I also replaced the mast on my Formula and it would never quite make it all the way down. I have lubed it with all kinds of different lubricants and it works great for a little bit then it gets washed off. So I gave up.
Camaro Owners Click Here
Firebird Owners Click Here
www.AutoTrix.net
antenna
By soadkrazy21 in forum General HelpReplies: 13Last Post: 11-04-2011, 12:11 AM -
New Antenna??
By BdAsBrd01 in forum Firebird / WS6Replies: 13Last Post: 05-26-2009, 04:28 PM -
Convert power antenna to fixed antenna
By Red 99 T/A in forum Firebird / WS6Replies: 21Last Post: 01-24-2009, 10:40 AM -
Antenna Won't Come Up All The Way
By KJax2010 in forum Stereo and ElectronicsReplies: 0Last Post: 08-18-2007, 05:24 PM -
Antenna won't go up.
By amstall in forum Stereo and ElectronicsReplies: 1Last Post: 06-06-2006, 06:15 AM
