Results 1 to 10 of 10
Thread: Camaro SS throwing P0410 code
12-01-2009, 08:50 AM #1
Anybody familiar with this code? Is this common to the Fbod?
2002 Camaro SS
37,xxx miles
Check Engine Soon (dashlight on)
Autozone Scan Results:
P0410
Troubleshooting P0410
Domestic brand
Secondary air injection system fault
Probable causes:
Circuit relay defective or open fuse
Connector and wiring
Air pump defective or hoses blocked
Anyone with experience know the most likely scenario?
I figured I'd ask the experts before pursuing.
Thanks.
12-01-2009, 09:41 AM #2
12-01-2009, 01:19 PM #3James Bond
- Aug 2007
- Texas
the description of the AIR system makes it sound retarded...it pumps in air to reduce emissions? how? all it does is dilute it.....the motor is still making the same amount of exhaust
12-01-2009, 03:13 PM #4
Thanks. I'll check the pumps and valves.
12-01-2009, 04:09 PM #5Senior Member
- Nov 2006
- Indianapolis
I will bet you it is a 99.9% chance your check valve on the air injection is mostly plugged. Common problem, easy to fix. Just look for your rubber air injection hose going towards the exhaust manifolds. Where the rubber connects to the metal pipe is a valve in between the rubber hose and the metal pipe, that is the check valve. If only one side is plugged, it is still best to replace both sides because the other side will plug soon....and no you can't really clean the valve, ask me how I know that LOL. The check valve prevents the exhaust from coming into the rubber hoses and burning them.
12-02-2009, 06:38 AM #6
It's likely water from condensation. We've had torrential rain and wild temperature changes. The car lives outside. Everything deteriorates in those conditions. I'm replacing window motors today. The car hasn't been 1400 miles since the last fix on that issue. I need a garage and a car cover.
12-02-2009, 04:23 PM #7
12-02-2009, 06:42 PM #8
check for a cracked line prior to the manifolds. Look at the main feed line. Also, verify that the pump is actually running. Could be a fuse or relay keeping the pump from running at all.
12-02-2009, 06:47 PM #9
Post #5 in this thread has a step-by-step diagnostic for the secondary air system: http://www.ls1.com/forums/showthread...ight=secondary
12-02-2009, 06:59 PM #10
Help: Engine Code P0410
By her ss in forum Camaro / SSReplies: 2Last Post: 06-10-2016, 04:05 AM -
P0410 Code
By theorangeguy in forum General HelpReplies: 3Last Post: 06-20-2013, 03:15 PM -
p0410 code and no ses light?
By Ortiz11b in forum General HelpReplies: 6Last Post: 09-16-2011, 07:14 PM -
99 vette throwing p0300 and p0410 codes..
By MachWon in forum Computer & TuningReplies: 6Last Post: 03-06-2010, 12:14 PM -
SES code P0410
By adham in forum General HelpReplies: 1Last Post: 04-21-2006, 01:40 PM
