Thread: Thermostat
    Member Skippy's Avatar
    Oct 2009
    Perkins, OK
    04 Pontiac GTO
    Thermostat
    Im sure this has been asked several time but here it goes. How do I tell which thermostat is in my 04 GTO? What is the outside diff. between the early model and the late model. I wanna get a 160 deg. but I dont know which fits my car. Please help, thank you.
    Ashes to ashes and dust to dust, if it wasn't for fords our tools would rust
    Member derbs's Avatar
    Jun 2006
    iowa
    IBM
    04 GTO
    I don't think that the outside housing would be diff. But I'd look into the SLP one if you were going to get one mine works fine.
    Oct 2009
    Perkins, OK
    04 Pontiac GTO
    I know that one is just a therm. and the other is a therm. built into the housing. I just dont wanna tear it apart to find out.
    Member The Silver Goat's Avatar
    Dearborn Michigan
    Qucik Silver Metalic
    2004 GTO - M6
    The housing the thermostat are separate. SLP sells a 160 that fits the housing. To take advantage of the theromstat you'll need to reprogram the fan settings.
    Mississippi
    Impulse Blue
    2004 GTO
    When was it built? Pretty sure the '03 built cars had the old setup but don't know when it was changed over.
    Oct 2009
    Perkins, OK
    04 Pontiac GTO
    The id tag on the core support says may of 04. I seen a picture somewhere once of the new and old housing side by side once but I cant find it anymore.
    Member pmolina0436's Avatar
    2004 GTO
    go to autozone...they have the mr gasket for like 13-15 bucks..and yea u need to get a reprogram so u can see/fell the diffrence.
    Oct 2009
    Perkins, OK
    04 Pontiac GTO
    im not installing it now, im just collecting stuff to do when I do a cam swap. Ill put everything in and then have it tuned all at once. kind of a kill two birds with one stone sort of a deal.
  1. 160 thermostat
    By V8MUSCLE in forum External Engine
    Last Post: 10-01-2009, 11:53 PM
  2. No thermostat?????
    By ggino85 in forum General Help
    Last Post: 08-03-2009, 10:22 PM
  3. 160 thermostat
    By 13nickels in forum General Help
    Last Post: 07-07-2008, 05:58 PM
  4. thermostat mod
    By Brent in forum General Help
    Last Post: 03-17-2008, 03:09 PM
  5. Thermostat?
    By '00T/A in forum External Engine
    Last Post: 09-27-2007, 08:35 AM
