Results 1 to 20 of 28
11-29-2009, 02:01 PM #1Senior Member
- Nov 2009
- NOVA
2002 C5 - M6 - Blue- 2000 Z28 - A4 - Pewter
How do you identify an LS6 from an LS1 intake?
Just like it says, how do you identify the difference? I'd like to purchase a used one, but I could've sworn the runners looked to be the same with a black casting? Or am I just an idiot? Ok, I AM an idiot, but how do you tell the difference?
11-29-2009, 02:04 PM #2
The bottom of the ls-6 is flat while the bottom of the ls-1 has two valley's with a hill in the middle.
ls-6 on left, and ls-1 on right the fins in this picture have been ground down on the ls-6 so the 98-00 coolant lines will not hit the bottom of the ls-6.
11-29-2009, 02:51 PM #3Awaiting Activation
- Oct 2007
- NC
SOM- 1998 T.A.
http://www.c5help.com/partnumbers.htm
I post this about once a week on some forum. Yes on the flat bottom if it is in your hands.....
11-29-2009, 08:27 PM #4Senior Member
- Nov 2009
- NOVA
Right on, thanks for the help! C5Z28 - Thanks alot for the picture!
11-29-2009, 09:01 PM #5Just me
- Nov 2006
- Broken Arrow, OK
Also, look at the part number on the driver side front. I am gonna make this a sticky since it comes up frequently.
11-29-2009, 09:04 PM #6Just me
- Nov 2006
- Broken Arrow, OK
Also, here is a link with instructions on how to go about swapping your intake:
http://ls1howto.com/index.php?article=5
11-29-2009, 09:34 PM #7
Well then in that case here is a pic of the opsu they don't mention. You have to unplug the damn thing and make sure you pull the brake booster over the sensor, this can only be done after you disconnect it. Get the fuel rail out of the way first so you can get in there to unplug it.
11-29-2009, 09:36 PM #8
And to save you $50 something on a kit you don't need here is where you grind the fins so the 98-00 coolant lines work.
11-29-2009, 10:59 PM #9your parts guy!!!
- cleveland ohio
trans am 00 ws6- 1998 camaro ss vert
LS6 intake manifold (01-02 F-body) = 88894339 (formerly 88890524, 88890523, 12561184)
LS6 intake manifold (from Corvette Z06) = ? (formerly 12573572)
LS6 intake manifold gasket set (contains 8 gaskets) = 12533587
LS6 intake manifold bolt = 12552344
LS6 intake manifold seal = 12560251
hope this helps.
12-04-2009, 09:04 AM #10Member
- Aug 2009
- Virginia Beach, Virginia
Black- 2000 Pontiac Trans Am WS6
Does anyone know if a kit is still made to plug the EGR hole in the exhaust manifold? I might be buying a LS-6 intake in the near future but won't be buying headers anytime soon. Thanks.
Scott
12-04-2009, 04:43 PM #11
12-04-2009, 07:49 PM #12
01-09-2010, 11:09 AM #13
stupid question probably, where can one find the #s on the intake? I looked quick, but my camaro is in storage without much light. its a 2000 Z28, any chance it has an ls6 intake on it?
01-11-2010, 05:19 AM #14
01-20-2010, 12:08 PM #15
I have a stock 99 LS1 TA. So from what I understand here all I need to convert is the LS6 manifold and some coolant port plugs... or do I need other items to get the performance, i.e throtle body, injectors etc? Will all of my components fit off of my old LS1 intake?
Maybe I missed it in the read somewhere?
I am a total newbe at this but have heard about the low $$$ performance the swap creates and am seriously considering it.
Thanks!
01-20-2010, 04:03 PM #16
08-14-2010, 05:05 PM #17
11-12-2010, 01:57 PM #18
pretty sure no ls6 intake has EGR hole in it so that's one of the easy ways to identify it from ls1 which would have EGR hole. that and flat bottom as mentioned on the ls6
11-12-2010, 03:21 PM #19
11-12-2010, 07:54 PM #20
Help identify these
By Larry in forum Almost Anything GoesReplies: 3Last Post: 08-16-2012, 10:05 AM -
Help: Help identify this car!!!
By Spikito in forum General HelpReplies: 18Last Post: 04-26-2012, 01:29 PM -
Can someone identify this?
By 1999slpss in forum General HelpReplies: 3Last Post: 03-08-2011, 04:30 AM -
Question: How to identify a LS6 intake?
By SMWS6TA in forum General HelpReplies: 12Last Post: 09-01-2010, 05:04 PM -
Identify this intake
By Luey357 in forum General HelpReplies: 0Last Post: 05-11-2006, 02:30 PM
