11-25-2009, 03:57 PM #1
Rolling forward problem!!! HELP!!!
I parked my T/A in the driveway going down. I must say my driveway is about a 35% angle. Anyways, I parked on it with the nose pointing down and forgot to pull the E-Brake. I have a manual car and left it in 1st gear. When I came back to it about an hour later it had rolled about 5 feet forward. Then when I started it up it had a bad "knocking" sound other than the usual from our cars. When I started going though it stopped completely. Anyone know why this is? Bad gears, clutch, etc?
11-25-2009, 05:14 PM #2
Even though its in gear the weight of the car is slowly turning the engine over.
11-25-2009, 08:54 PM #3
drive
drive it and if it doesent throw 1st gear out or grind major then you did not mess up your transmission .
11-27-2009, 01:03 PM #4
11-28-2009, 05:13 AM #5Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
1sr gear is the easiest gear for the cars weight to overcome. You need to put it in a taller (higher) gear. I always put mine in reverse and pull the E Brake.
Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
11-28-2009, 06:19 AM #6
Signs of a worn clutch...
11-28-2009, 07:11 AM #7Senior Member
- Apr 2008
- Madison, WI
you have this backwards(its easy to do, I do it all the time). 1st gear or reverse are the best one to choose because they create greater resistance in the drivetrain to try and turn the engine over. Reverse is slightly better (in a T56) because it is a lower gear (higher numerically).
11-28-2009, 07:13 AM #8
11-28-2009, 09:00 AM #9
Cutlass is right, usually indicates low compression in the engine, try putting the nose of the car down the driveway and parking in reverse, don't forget to cut the wheels and lock the wheel just in case.
Anyone else looking forward to Futurama?
By Mr. Luos in forum Almost Anything GoesReplies: 23Last Post: 06-27-2010, 10:21 PM -
Flash Forward
By DrMilhouse in forum Almost Anything GoesReplies: 4Last Post: 05-24-2010, 05:59 PM -
Spring Forward!!!
By MrMasterCraft in forum Almost Anything GoesReplies: 8Last Post: 03-14-2010, 11:26 AM -
anyone use the jba cat forward headers
By momsls1 in forum External EngineReplies: 1Last Post: 08-25-2005, 06:44 PM
