Page 1 of 3 123 LastLast
Results 1 to 20 of 60
    Junior Member Jager686's Avatar
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    Wink 93-97 to 98-02 Full Body Conversion *Guide*
    Full BODY 4th Gen Conversion
    Well I see alot of ppl. asking for someone to explain how to do this so after doing it fully myself i can, but i wish i took more pics while i was in the process of doing it. There's already a highly detailed guide for the camaro " http://www.bfranker.badz28.com/fbody...ontendto98.htm " but not for the Birds however its a little similar. If you have any questions feel free to ask, cuz i asked a million b4 I started.
    Items needed for Front Clip Conversion:
    **I got most of my parts off of ebay, and if u going to go through GM for the parts, your better off buying a new car.
    now when buying parts for the conversion make sure their 1998+ plus the desing ur going for: FIREBIRD, FIREHAWK, TRANS AM
    Fenders $100-200 x 2
    Hood $200-900 Stock "non ram air" is really cheap unless u want Ram Air
    Front Nose $200-400
    Front Fender Bracket (2-pieace) $50 x2
    Headlights $250 - 350 x2 GM wants about $1,000
    Fog Lights $20 - 100 depends if ur going for stok or aftermarket
    Turn Signal Housing $25 x2 and Light Sockets ? x2
    Side Markers $40 for the whole set
    Front Bumper Center Support $40
    *hard to find on ebay
    Front Bumper Impact Bar Absorber $60
    Some extra nuts and bolts
    Rear End Clip Conversion
    Rear Bumper $200
    Tail Lights $200- 300 think GM wanted like $800
    Hatch $350
    *depends which one u want, Highrise is more spendy.
    Side Markers $30
    ** You can also put on the side skirts "molding on your rocker panel", but i didnt..
    Ok, to go from the early 4th Gen Bird
    to the late 4th Gen Bird
    Step 1.
    A. Disconnect the battery
    B. Take off the hood and the underbody weathershielding
    Step 2.
    Remove the Fenders and Front Nose
    **i took my doors off also while i did this, but i was repainting..
    *remove the old front nose brackets also, you may need some WD-40..
    Step 3.
    Remove Headlights and support.
    **the long plastic support that goes from headlight to headlight...
    Step 4.
    Remove front nose foam support.
    1/2 way there!!
    Step 5.
    A. Put the new front fender brackets "12 amd 17" on and the headlights on also.
    [URL=http://img31.imageshack.us/i/scan0001nqb.jpg/][/URL
    **ur gonna have to splice the cables for the headlights otherwise they dont fit or buy the female end also.. make sure u wait to final fit these till u have the rest on too or youll end up what i did where they scratched the hood**
    B. Replace the old parking light socket with the new one..
    Step 6.
    Put the new front Foam Nose absorber "6 and 7" on and the Center nose support also..
    **really easy, bolt off and bolt new one on..
    NO BALLS -> NO LIFE
    1994 V6 Salvage FIREBIRD
    Full 98-02 T/A Body and T-Top Conversion Completed..
    West Coast Creations Hood
    American Racing Thrust Rims 16"
    Engine swap next year debating wat engine
    Build your own car like a man, dont be a pussy and buy one!
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    Step 7.
    Put on the hood, fenders, and Front Nose
    you can use your old struts and gear from your old hood to the new one..
    Take your time aligning everything up it look better in the end.. My Semi-finished BABY!!
    Member supercopone's Avatar
    Oct 2009
    Houston
    2002 Z28 B4C
    is urs a six banger?
    Member Pickle86's Avatar
    Apr 2009
    kanas city Mo
    2000 Trans am ws6
    headlights look like they would scrape.
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    Quote Originally Posted by Pickle86 View Post
    haha u noticed, they did at first only cuz i slapped it all together the last minute for college but i got it taken care of now.. and yes its a 6banger for now..
    Apr 2009
    kanas city Mo
    2000 Trans am ws6
    oh ok right on. good thing you got it fixed haha
    Pittsburgh
    2008 Hummer H3
    I realize you just got it together, but holy bad fitment bro.. Gotta get on that before the paint starts to chip on your edges..
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    I didnt take many pics while i was doing this however its really easy however your gonna need someone to help you with the hatch..
    *You can use ur original lights fot the newer 98+ tail lights..
    Step 1.
    Remove the tail lights
    Step 2.
    Remove the Bumber and disconnect the side marker
    Step 3.
    Remove the hinges on the hatch and remember to disconect the power and the GROUND!! which are located by the top light..
    Use a board or something to hold the hatch up.
    Step 4.
    Have 2 ppl on each sidde of the hatch while u remove the hatch the hindges so it dont drop on your ass..
    Step 5.
    Install the new bumper and connect the side markers also..
    Step 6.
    Install the hatch before u put the tail lights on so u dont scuff them putting the hatch on.
    Make sure its aligns correctly so it closes and locks.
    Step 7.
    Intstall tailights and center pieace
    YOUR WELCOME!
    Pittsburgh
    2008 Hummer H3
    Op, if you were to put a blower on that car, I'm pretty sure you'd have no trouble keeping up with a stock B4C. Built turbo Buick GN's have been pulling wheel stands for years..
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    Quote Originally Posted by supercopone View Post
    ur building a fake trans am....how much do u have in this?
    Does it really matter? its "my" 1st project car ntm im looking at a ls7 to drop in it next year then ill repaint it AGAIN lol
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    But i chose not to go the route! k thanks the end!
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    but it didnt cost much, plus i had a whole boring month to kill and i didnt want to keep the old front bumper so i did it. IDC if its "posing" as a trans am, not me with the problem and i didnt create this thread so u can burn on my car. Created this thread to be informative to those who are thinking about doing it.
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    any1 know where i can find a t-top conversion and v6 to v8 conversion guide??
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    Quote Originally Posted by Jager686 View Post
    Believe it or not, some of the structure is already there on your car for the T-tops. The center support is under your head liner. You'll have to do a search but someone here @ the site has done the conversion.. I'm not sure if there's a kit for it though. There's a lot that will need changed for the v8 install you're planning but also has been done buy a member here too. Have to do that search too.
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    Ya im one of the lucky ones that has the outline for the t-top under the head liner BAH! dont remind me, im aware theres alot to be changed for v8 but i might as well start prepping the car now b4 snow comes
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    Ya im one of the luck ones that has the outline for the t-top under the head liner BAH! dont remind me, im aware theres alot to be changed for v8 but i might as well start prepping the car now b4 snow comes
    I feel ya. I was gonna do an LS1 conversion too in the spring. But the guys here got me thinkin' blower. So I put it to the wife she said go for it..
    Pittsburgh
    2008 Hummer H3
    Hehehe... The Doc is in..
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    im so jealous
    ..... since when did trans am get all cheapy on auto trader !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Pittsburgh
    2008 Hummer H3
    Wink
    im so jealous
    Well I gotta finish my other project before I can start the new one. Kinda was the deal with the wifey. But I can stock up on parts in the mean time.
    college station, tx
    sold: 1999 firebird
    you are way better off buying an ls1 trans am,
    seriously, you have an lt1 body, and doing an lt1 swap would be costly in itself, but putting an ls motor into lt1 body means even more parts would need to be swapped such as entire fuel system etc and so forth
  1. Zombie Slaying with a Full-Auto Glock 17 Conversion
    Last Post: 05-14-2012, 04:20 PM
  2. Full ZR1 body kit installed on a Z06!
    By Mr. Hyde in forum Corvette
    Last Post: 08-08-2009, 10:48 AM
  3. Ultimate Paint and Body Guide Part 7 - Under The Gun
    Last Post: 04-27-2007, 06:16 AM
  4. Ultimate Paint and Body Guide Part 8 - There's The Rub
    Last Post: 04-27-2007, 01:50 AM
  5. Throttle body bumpstop mod guide?
    By 6spd in forum External Engine
    Last Post: 01-15-2006, 11:42 AM
