Results 1 to 20 of 25
    Junior Member jrabbet's Avatar
    Nov 2009
    NC
    1999 Z-28
    What to expect????
    Ive got a 99 Z 6 spd. with ALOT of mods. Went to start it Monday after a week and a half of siting and it starts and pops all at once. Now I got a window in the pan in line with #2 cylinder. I havent started tearing into it yet, The only thing I can figure is broke rod.. ganna try to get it out this weekend. Other than a leaky injector what could have caused it?
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    bearings went bad?
    Nov 2009
    NC
    1999 Z-28
    5k on the engine. no noises at all in the past. broke when it fired first time..
    Apr 2002
    San Jose
    could be broken rod if #2 was hydrolocked but that's kind of hard to really do. You may just have to start tearing into it
    fuel puddle would be my best guess...
    Nov 2009
    NC
    1999 Z-28
    Thanks guys, I will have it out this weekend.. Wish me luck
    Aug 2009
    Dover Plains, NY
    1999 Z-28 camaro
    maybe a soft rod....if was a new one. had that happen on a race car before
    Member NoscamaroSS's Avatar
    Durant, Okla
    2002 Camaro
    Have you had alot of rain lately?
    02 Camaro
    PRC Stg 2.5 5.3's, Futral F14, PP Typhoon intake, True duals, Performabuilt tranny, & 3500 convertor, HSW plate kit.
    *Old Time* 10.90@ 125mph
    Nov 2009
    NC
    1999 Z-28
    Yes, That is the reason for it sitting..
    Durant, Okla
    2002 Camaro
    Ive seen a couple of instances where water "rained down" on the motor from the cowl. Somehow the water made its way into the motor, im gonna assume around the intake gasket or possibly the injector o-rings, and when they are started, they pretty much immediately throw a rod.
    Nov 2009
    NC
    1999 Z-28
    The engine is dry. The only way it could get water on it is if it were to sweat
    NC
    SOM
    1998 T.A.
    Get your injector for that cylinder checked. You wouldn't be the first one to break a rod from this........
    Nov 2009
    NC
    1999 Z-28
    Ok cool. I was hoping I wasnt the only one..
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    Dr.Crash had that happen to him apparently, he might be able to help but you may have to e-mail him as he has not been on for awhile.
    402 Guru 402 Guru's Avatar
    Jan 2008
    las vegas
    02 Trans Am T-tops M6
    +1
    +1 if you had a leaking injector it could dump raw fuel into your cylinder and have to much combustion and Pop a cylinder right in half ( Sounds like a gun shot is the only at to describe it )the only way to tell 100% is to start tearing the heads off and inspect the damage worst case that is and you have some cool lookin paper weight's like the notorious #7 cylinder on the ls1 that just go out of no where. Good luck with the Tear down give your self a weekend with some buds or do it yourself like i like to do then u have plenty of time not to rush , what kind of mods do you have ????
    Nov 2009
    NC
    1999 Z-28
    Texas Speed 404 Stroker, Fast 92 intake and Nick Williams Throttle Body 95mm, Stage 2.5 heads, Futral Cam, Diamond pistons, ARP studs, Forged bottom end, Fast Toys lid, 1-5/8's AR headers, Fab 9 in w/full spool, 35 spline mosers, Chrome moly Drive Shaft, UMI safety loop, UMI Trq Arm, UMI Panhard Bar, FLSFC's, Hotchkiss springs, 5.0 short throw shifter, cartech level 7 clutch, Tick Master/Slave/Bleeder Kit, and a custom dyno tune by RPM
    Nov 2009
    NC
    1999 Z-28
    I run a restoration shop, so I have everything to do it myself, rushing wont be necessary.
    NC
    SOM
    1998 T.A.
    Quote Originally Posted by un17real View Post
    It is not from too much combustion it is from the cylynder being so full of fuel that it will not compress so the rod breaks on the compression stroke......
    Jan 2008
    las vegas
    Thumbs up
    Quote Originally Posted by SOMbitch View Post
    well i am engine builder for 15 years and it could very well be the rods or the piston its very hard to tell 100% unless you tear it down so we are both dead on
    NC
    SOM
    1998 T.A.
    If it is a leaky injector I bet 10-1 it is the rod. Every case I have seen it has ALWAYS been the rod........
  1. How much should I expect to pay for an LS1..
    By first01SS in forum General Help
    Last Post: 03-30-2010, 12:47 PM
  2. How much should expect I to pay?
    By nmartin in forum Drivetrain
    Last Post: 11-20-2009, 05:48 PM
  3. what to expect
    By 1998 T/A in forum Firebird / WS6
    Last Post: 10-14-2008, 03:33 PM
  4. Question: New cam...what to expect!!??
    By TheGimp711 in forum Internal Engine
    Last Post: 09-10-2008, 08:08 PM
  5. what should i expect
    By 1fastgto in forum GTO
    Last Post: 04-08-2007, 03:01 PM
