Results 1 to 2 of 2
Thread: key - fob program
11-16-2009, 05:54 PM #1Junior Member
- Nov 2009
- chicago
black- 2004 gtp
key - fob program
We have only one key/fob for 2004 GTO, I purchased a replacement key/fob, I can get the key cut at a locksmith, but how do I program the fob? dealer wants 75$ just to look up the security codes and 75 to program. Is there a manual method
11-16-2009, 06:06 PM #2Senior Member
- Apr 2008
- Madison, WI
Programming Transmitters Without Scan Tool
1. Turn the ignition to ON, then wait 10 minutes for the next step in the programming sequence.
2. After the 10 minutes has elapsed, the car horn will chirp once. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
3. Leave the key to the ON position for 10 minutes. After the 10 minutes has elapsed, the car horn will chirp twice. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
4. Leave the key to the ON position for 10 minutes. After the 10 minutes has elapsed, the car horn will chirp 3 times.
5. Verify that the security indicator in the instrument cluster has stopped flashing and attempt to start the vehicle.
6. Turn the ignition to OFF and remove the key from the ignition switch.
7. Move approximately 3 meters (10 ft) away from the vehicle and test the transmitter functions to validate that the transmitter has been programmed successfully.
E-Rod Program
By Pro-StreetLS427 in forum LS2/LS3/LS4/LSxReplies: 4Last Post: 11-29-2010, 11:03 AM -
What program do you use?
By Justin23454 in forum Computers / GamingReplies: 26Last Post: 06-25-2008, 06:14 AM -
need help with mp3 program....
By clg82 in forum Almost Anything GoesReplies: 11Last Post: 03-18-2008, 07:17 PM -
Question: Should i program or not?
By TransAmFanatic in forum General HelpReplies: 3Last Post: 02-20-2008, 05:55 PM -
Best ECU Program?
By plumcrazyhemicuda in forum Computer & TuningReplies: 1Last Post: 03-25-2006, 02:58 AM
