Results 1 to 14 of 14
11-12-2009, 09:58 AM #1
Can't find PCV part! (w/o buying full assembly)
Ok, this is ridiculous. I need the rubber boot that fits around the PCV valve on a 1999 Trans Am. GM will only sell it as a set, so, from them, $111 for the whole assembly just so that I can have one rubber boot. From gmpartsdirect.com it is about half the price, but still, this is crazy.
Does anyone know of a different way to try to get a hold of this part, without buying extra parts that I don't need to replace?
On the GM diagrams showing the intake manifold, it is part 591. It is literally what the PCV valve is placed into. It is a rubber boot, and there is a small slit on the side for some sort of engine block electrical ground to fit into.
Thanks!
Nick
11-12-2009, 10:29 AM #2
have you tried taking it to any of the auto parts stores and see if they have any that match that or that part I would go to an auto parts store and give them the part number and see if they have them!!
11-12-2009, 10:51 AM #3Detailing + Design
- Pittsburgh, PA
where did you find a picture? I completely replaced my PCV with braided hoses and i can't tell what you're talking about? I looked on GMpartsdirect and they don't have an illustration.
11-12-2009, 11:00 AM #4
The picture was a printout from the dealer of an exploded view. It is a part of the assembly that gmpartsdirect.com has...
It is literally the rubber boot / grommet that the PCV valve fits into, on my car is it located about 3-4 inches to the left of the intake manifold, and the rubber tube actually connects to the left side of the intake manifold.
11-12-2009, 11:07 AM #5
No luck on auto parts stores... They all say it is a dealer only part. I ended up getting a random PCV valve which had 1/2 inch in/out so that I could replace it, but my car has not been running very well lately and I think that the fact that I am not using the correct PCV valve probably has at least a little to do with it. :|
11-12-2009, 11:12 AM #6your parts guy!!!
- cleveland ohio
trans am 00 ws6- 1998 camaro ss vert
get me a picture of it i'm pretty sure i have it.
11-12-2009, 12:20 PM #7
Great, I will try to take one tonight. Do you have an extra one or something? It basically looks like the shape of a beer bottle with a small slit on the wider side...
I just realized, I don't have the thing any more. I tossed it when I hooked up my quick fix using a different PCV valve and rubber hoses...
11-12-2009, 02:58 PM #8
This is what I did, really helps
http://www.ls1.com/forums/showthread...ight=pcv+valve
11-12-2009, 04:35 PM #9
How about you just go to a junkyard?
11-12-2009, 04:58 PM #10
11-12-2009, 05:23 PM #11
This is also what I attempted to do, but I couldn't use the same (correct) valve, I am using one that had a male connector on both ends. Thus, I think it is really screwing with how my car is acting.
I think this is great, I am going to try to do what you did and see if it works for me.
Thanks!
PS, my rubber boot looked exactly the same as yours, all burnt up in one spot. :|
11-12-2009, 05:28 PM #12
Did you ever figure out why they have the electrical ground? Does it actually benefit the PCV, or was it placed there just because it was close to where they needed it?
11-13-2009, 02:05 AM #13Detailing + Design
- Pittsburgh, PA
i dont' think that's a ground, I think that's just there to hold it in place.
11-13-2009, 01:32 PM #14
Is there a big difference between the normal PCV valve with the larger opening and then smaller opening version?
Which is better?
Engine Assembly Tips Part 2 - 16 More Engine Assembly Dos An
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 10-11-2013, 05:00 PM -
Help! I Need to find this part/part number!
By BOILER_WS6 in forum Suspension and HandlingReplies: 9Last Post: 10-25-2010, 11:10 AM -
Can anyone help me find this part?
By JayTA98 in forum External EngineReplies: 2Last Post: 05-22-2009, 09:29 AM -
Trying to Find part for interior
By tomf301 in forum General HelpReplies: 3Last Post: 07-18-2007, 06:35 PM -
Running and Racing Reliably Part III: Final Installment: Top-end Assembly
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 10-25-2006, 01:57 PM
Thats what I did. Well not exactly but close to that.
