    Senior Member rajiv1998's Avatar
    New Jersey
    1998 Pontiac Trans Am
    Help with my new notebook
    So i recently got a new HP notebook and now the dam thing is slugish. It use to be so damn fast but now it takes a while to boot up and launch explorer. Its just plain slow but I have good configurations and they include....
    4GB RAM
    320 Hard Drive
    Vista
    AMD 64bit processor
    I always run ALL the updates on it and clean out my C disk almost once a month. Any ideas.
    Also in my microsoft word everytime i type a word and hit space a little dot come in between the word and where my cursor is. My paragraph button (show/hide) always comes on even when its unchecked at the top of the ribbon. Any1 ideas???
    Impounded 86 IROC-Z's Avatar
    Everything fiberglass
    2005 Amberlamps
    Probably have a ton of start up programs / spyware / adware / etc
    Find a good cleaner and try that.
    As for the MS word thing, yeah the dots are caused by the paragraph option being selected, not sure why it would be on automatically each, it might be a selection in the options so you might want to look through the settings to see if something like that wasn't accidentally turned on, by a shortcut key or otherwise.
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Probably alot of adware/spyware. Do a free scan and see. I went to www.malwarebites.org ( I think ) And that rid my CPU of alot of bad things. Completely free.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    what you are running into is a lot of programs being started up with windows...you dont need itunes to auto start with windows or your im and etc etc ..go to the task bar..see what programs are running ....click on them..go to the options and make sure that you un-select startup when windows starts etc
    Shepherd, Michigan
    98' trans am
    id assume you have vista..not sure if it works in vista..but put in your vista cd..and in the search bar type cmd ...then right click it and select run as administrator.....
    once it opens up type in sfc /scannow ..and let it run
  1. Ordered something for my Dell notebook
    By SiggyZ in forum Computers / Gaming
    Last Post: 03-06-2008, 11:16 AM
  2. HP Notebook
    By TRAINSLS1 in forum General Classifieds
    Last Post: 10-21-2007, 05:15 PM
