Results 1 to 3 of 3
Thread: My Nitrous Nozzle
11-07-2009, 07:31 PM #1Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
My Nitrous Nozzle
Sooooooo...I went to install my nozzle in my silicone coupling using the Nitrous Outlet adapter and discovered that it did not allow the nozzle to go more than half an inch into the tubing. Since the nozzle sprays at a 90* angle, I was thinking that about half of the Nitrous/Fuel mixture would end up on the tubing, rather than in the intake. So, I did some thinking, some measuring, some cutting, some more measuring, some drilling, and finally some installing. This is the result:
When I put the nozzle in the tubing, it was not very sturdy, and I think that if I when I went WOT, the incoming air would dislodge the nozzle and bad things would happen. My solution was to drill 4 holes in the tube and use them to attach fishing line to the nozzle in order to keep it mounted firmly and centered. I tested the line fitting before I siliconed the nozzle in...I think I will have to mount something to hold the upper radiator hose down half an inch, so the lines can fit comfortably, but I don't think it will be a problem.
Oh, and the whole reason the nozzle is mounted where it is, is because I wanted the stealthiest setup possible...the tank is in the spare tire area, the buttons are in the ashtray, the electronics are in the console, the solenoids are under the cowl, the lines will be covered with wire loom, he nozzle is under the intake coupling, and the purge is on the nose, rather than the typical windshield cowl.
11-08-2009, 03:15 AM #2Junior Member
- Nov 2009
- Lafayette LA
RED ultra Z hood 125 shot- 02 Z28 3200 stalled
this is where mine is might help
11-08-2009, 04:51 AM #3
Very innovative approach imo. Nice work!
nitrous nozzle setup cheap and various size nitrous hoses
By RARON455 in forum Parts For Sale / TradeReplies: 3Last Post: 11-21-2011, 06:30 PM -
Nitrous nozzle in rubber bellow??
By WS6chick in forum NitrousReplies: 9Last Post: 10-29-2009, 12:51 PM -
f/s Nitrous express dual nozzle 100 to 300hp kit like new
By quick777 in forum Parts For Sale / TradeReplies: 4Last Post: 07-27-2007, 06:13 AM -
need nitrous nozzle
By ls1marine in forum Western MembersReplies: 6Last Post: 09-06-2006, 01:40 PM -
nitrous nozzle testing
By mrr23 in forum NitrousReplies: 7Last Post: 04-20-2006, 07:31 PM
