Results 1 to 15 of 15
Thread: Line Lock
11-06-2009, 08:11 AM #1
Line Lock
I have linelock installed on my car. The hardware, solenoid, shifter button, etc is present. I recently went to the stealership and got them to diagnose the no starting issue and in the process, they disconnected the linelock. Could someone help me reconnect it? I looked under the hood and saw two wires coming from the firewall that I think go to the brake solenoid or battery....Here's what I have: Button on the shifter, on/off switch in the ashtray, solenoid mounted near the brake distribution block. If someone could tell me the electrical way to hook this back up, given what I have, I would really appreciate it.
11-06-2009, 08:33 AM #2Senior Member
- Aug 2001
- San Diego, CA
383 w/Meth & ProCharger- 2001 Camaro Z28
There's only a 12v source input and a ground in the electrical setup. If you can trace those down to make sure they're both connected to something, well to the correct place I should say. Also trace the wires to the button to make sure they're connected. If you have a voltmeter to ohm out the wires, that would help a ton. Here's a link I found which isn't 4th gen fbody specific but regardless, it's all the same. Take a look at that and see if it helps you any.
Click here
11-06-2009, 09:00 AM #3
Thanks Intimidator, that was very helpful.
11-06-2009, 09:05 AM #4
the slp line lock pulls power from the block on the drivers side right by the fuse boxes. It grounds under the dash I believe.
11-06-2009, 09:22 AM #5
11-06-2009, 09:24 AM #6
11-07-2009, 06:52 AM #7
Ok, I will let y'all know when I diagnose the setup and get it hooked back up. Thanks for all the info.
11-04-2010, 03:55 PM #8
Anyone who has linelock hooked up, what size fuse do you put inline to the power line?
11-04-2010, 04:08 PM #9
man......I don't remember but for some reason I think it was a 15 amp. Hold on, I have a picture on here somewhere of my install that might show it.
11-04-2010, 04:09 PM #10
nevermind....that was the wideband install I was thinking of.
11-04-2010, 05:44 PM #11
You shouldn't go bigger than 15. my .02
11-04-2010, 07:44 PM #12
Thanks man, thought it might be a 15, but just wanted to be sure. Thanks again.
11-05-2010, 06:13 AM #13
I believe my SLP Line Lock came with a 10 amp fuse. I would have to look to be certain though.
11-05-2010, 09:05 AM #14
Let me know Jeff. Thanks
11-05-2010, 01:02 PM #15
10 amps it is.
Question: line lock
By jodmari in forum General HelpReplies: 3Last Post: 05-07-2015, 06:21 AM -
line lock
By JunkyardZ in forum General HelpReplies: 8Last Post: 02-27-2012, 04:19 AM -
Line Lock Look
By pajeff02 in forum General HelpReplies: 37Last Post: 11-04-2010, 09:16 AM -
SLP line lock *NIB*
By Packy in forum Parts For Sale / TradeReplies: 5Last Post: 03-31-2009, 02:02 PM -
Line lock/ brake line ?
By 2001z in forum Suspension and HandlingReplies: 3Last Post: 04-01-2007, 05:42 AM
I have the SLP line lock as well. It's been a while since I looked at my hookup...but yeah I remember getting the 12v from next to the fuse box and think I found a ground close by as well.
