Results 1 to 2 of 2
    Nov 2009
    yuma az
    ble
    02 WS6 Firebird
    misfire/skipped cylinders/backfire upon throttle
    ladies and gents, i am new here and have ben having prolems with my engine. first some general basics about the car so you know what i am dealing with 02 WS6 TA, LS1 with following mods: comp cams oversized cam (dont know the duration but it lopes like no-ones business), 48 lbs injectors, ported MAF, slp headers, slp airbox lid, no cats, no muffs (they were removed by desert motor sports), pcm was retuned for everything. i havent had the diagnostics done yet since i am currently serving in afghanistan, but will have it done when i get back.
    ok here is my problem. it idles fine, runs fine with regular to moderate acceleration, but when you put it to the floor it almost seems like a couple of the cylinders are either misfiring or being skipped and it backfires a couple of times. the power is not what it should be making. once i get home i plan to replace plugs, plug wires, fuel filter and i was wondering if anyone could think of anything else that could be doing this. maybe cam pos sensor? o2 sensors (the ones before the cats since i am not running cats)? any help would be greatly appreciated.
    Racine, WI
    1998 Pontiac Trans AM
    I just started having similiar problem..nothing has been altered on the car except a new fuel pump recently..I ran the code reader and i got PO151, PO103, PO171, PO174. The most recurring problem is o2 sensor, MAF, or vacume leak. But i cant even accelerate. small acceleration wont move the car..and it backfires in the front and back...if i floor it it gains speed slowly...but works.
  1. Help: 02 WS6 Misfire on all cylinders
    By UT Trans Am in forum General Help
    Last Post: 03-07-2015, 05:13 AM
  2. Help: Random Misfire Multiple Cylinders SEL Code
    By davidz28 in forum General Help
    Last Post: 04-29-2012, 05:52 PM
  3. Idle problem, misfire and backfire
    By afattitude in forum General Help
    Last Post: 11-14-2009, 07:51 AM
  4. Help: misfire in all 8 cylinders
    By XxChOpPeRcHiKxX in forum General Help
    Last Post: 06-05-2009, 08:59 AM
  5. Backfire/Misfire at high RPM's
    By cobrakiller02 in forum General Help
    Last Post: 08-09-2008, 08:04 PM
