Thread: white smoke????
    Member ls1wallen's Avatar
    Jul 2009
    Saint Peters, MO
    2001 Formula
    white smoke????
    so i have a cut out and i have noticed for the past few weeks even after my car has warmed up its still smoking white. idk if i have moisture built up in there and its just steaming out. any help please
    The color chart:
    White = coolant
    Blue = oil
    Black = fuel
    In cool, damp weather a car may still exhibit some white smoke even after it is warm as water is a by-product of combustion. Does the exhaust smell like coolant? Have you checked your coolant level?
    Awaiting Activation jsremmos's Avatar
    Tyler,Texas
    Black on Black
    2001 Trans Am ws6
    lets hope that smoke doesnt smell sweet head gasket
    most likely condensation but it wouldn't hurt to check it out. How does your oil and coolant look? These motors make a ton of condensation. You can hear it burbling in the mufflers of the GTO and it takes a while to burn it out of there. They even have drain holes in the mufflers. The bird pours it out too....pretty common but check your oil and coolant and see what they look like.
    Jul 2009
    Saint Peters, MO
    2001 Formula
    Everything is full. I think I have alot of water in there. I hit the gas a few time and water came out. It didnt smell like anything.
    Quote Originally Posted by ls1wallen View Post
    Probably ok then.
    Pittsburgh
    2008 Hummer H3
    Short trips can also cause a heavy build up of water in the exhaust. Especially if the exhaust is not getting hot enough to burn off the excess condensation. This can give the appearance of blown head gasket aswell.
    in my Trans Am
    2000 Trans Am WS6
    +1 also extended idling without a long enough trip to burn the condensation off can cause this. May want to keep an eye on your oil to for a milky looking substance on the oil cap, filler tube, etc. this is a sign of excess water in the oil which is not good. If you have this you know you need to run the motor out longer to burn off the water and keep it "clean"
  1. Weird white smoke
    By Lunatikgixxer in forum Firebird / WS6
    Last Post: 04-19-2011, 11:04 AM
  2. Question: White smoke - tailpipes
    By bhamTA in forum Firebird / WS6
    Last Post: 03-11-2010, 12:58 PM
  3. White smoke
    By irbaboon in forum General Help
    Last Post: 02-16-2008, 06:12 PM
  4. White puff of smoke
    By gsxr1k6 in forum Internal Engine
    Last Post: 08-01-2007, 08:59 PM
  5. white smoke
    By 35thAnniZ28 in forum Internal Engine
    Last Post: 07-30-2007, 05:54 AM
