    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    Gas resistant epoxy / glue ???
    I have a small engine that the float in the carburetor went bad. So, I found a set of plastic floats that fit & used JB weld to attach them to the arms. It lasted about 2 weeks & the JB weld fell apart...
    Anyone know what I could use that will hold up to gas ???
    Senior Member 35thAnniZ28's Avatar
    eating bulldog
    son of biscuit
    Yes,there is an aircraft adhesive used for keepig water,fuel (jet fuel or diesal) off of bolt heads and nuts and is sticky as sticky as can be,it's called pro seal(type2),really messy and needs to be mixed..how you'll get it..I dunno
    Feb 2007
    St Thomas, PA
    Never hears of that, but I will investigate !!!
    Someone said 3M has something too...
    I'd buy a new float, but they don't make this one any more...
    Member Adam_94_T/A's Avatar
    Oct 2009
    North Carolina
    1994 Pontiac T/A
    3m window weld lol use it when putting windows back in the vettes after paint that is some tough stuff
    Member Benner's Avatar
    Delaware, OH
    2001 GrandPrix GTP
    Some of the best stuff i've ever used at my old dealership I used to work at was called Duramix by 3M. About $50 for the stuff but it's worth it and they should have something for your needs.
    Feb 2007
    St Thomas, PA
    50.00 is nothing if I never have to open this carb again !!! LOL !!! Thanks !!!
    Delaware, OH
    2001 GrandPrix GTP
    No prob. There's a couple different kinds so make sure of which one you're getting and make sure that it is gas resistant. And you only have about 15 seconds to get it set correctly or you may as well buy a new carb cause it'll never come back off.
  1. Trim glue
    By ws6freek in forum Appearance Section
    Last Post: 09-03-2009, 01:14 PM
  2. Help: Epoxy Fix for Radiator
    By Customta98 in forum General Help
    Last Post: 08-07-2009, 10:30 PM
  3. ummm Question about the glue.
    By FSANE in forum Almost Anything Goes
    Last Post: 12-15-2008, 07:53 AM
  4. Super glue on paint.
    By Brownboy2020 in forum Showcar and Detailing
    Last Post: 04-04-2007, 08:36 AM
  5. super glue
    By fuelslut in forum Showcar and Detailing
    Last Post: 02-25-2006, 07:41 AM
