Results 1 to 13 of 13
    Forest City, NC
    1999 Camaro SS
    Automatic to 6 spd, need help
    I have a 99' SS with an automatic, i want a 6 spd, where can i find a complete changeover kit? what all do i need? how much do you think it will cost? Is it more trouble than its worth?
    Feb 2006
    Los Angeles
    Navy Blue Metalic
    1998 Camaro Z28
    Exclamation
    its easy to do a conversion, all you have to do is get parts and common sense,
    t56
    clutch, presure plate flywheel
    clutch master cylinder
    slave cylinder with throwout bearing
    manual pedals
    6 speed center console
    repgrogram your ecm to an m6 program
    pilot bearing
    shifter
    Feb 2006
    Alabama
    2001 Z 28
    what about cutting the floor pan? and is there already a spot for the slave cylinder?
    Feb 2006
    mt vernon tx
    2000camaro
    ?s about conversion
    i have a 2000 b4c camaro and would like to go to six-speed as well and have talked to several people about the wiring harness. no one seems to know whether or not i will have to change the harness out or not. i know i can do everything else, i just don't know whether to change the harness or to leave alone and just reprogram the ecm. any help will be appreciated on this.
    the hole for the shifter you can measure out from another car. my plan is to find a wreking yard that has an ls1 six-speed car and buy all of the necessary parts for the conversion and perform the conversion myself
    the mechanics of the conversion are not hard, it's just the wiring issues i'm having trouble finding answers to. any help will be appreciated on this.
    Feb 2006
    mt vernon tx
    2000camaro
    not more trouble than its worth
    if your a gearhead like me, and ya love to shift gears, then you will find that it is not to much trouble to do conversion. it is well worth it to feel the power. and this way you don't have to worry about more payments.
    Happy speed shifting
    Feb 2006
    Los Angeles
    Navy Blue Metalic
    1998 Camaro Z28
    Exclamation
    you can splice your existing harness, but its better if you get a new harness heres a link on how to convert a4 to m6
    http://www.afrashteh.com/tranny_pics/T56.htm
    it has pics and everything, you have to cut hte floor board, scary but now hard, the slavy goes inside the bellshousing if you have an ls1, the slave goes just outside the bellshousing if you have an lt1, ths step by step instructions are the most thourough for being free and its easy,
    Feb 2006
    mt vernon tx
    2000camaro
    thanx a lot for the help
    thanx for the help, i don't think i would have been able to find something this detailed on this. it will help a lot. thanx a mil
    Feb 2006
    Alabama
    2001 Z 28
    Yea I am kind of suprized that there is not a lot of info on doing the swap. been searching without much luck this article sounds like it will help. Thanks
    You Snooze You Looze!!
    Modding is an Addiction bww3588's Avatar
    Chillicothe, Ohio
    Feb 2006
    Alabama
    2001 Z 28
    Thanks for the info once done I will post how it works out.
    Member tici's Avatar
    Zurich - Switzerland
    1998 M6 vert TA
    Also don't forget the rear end (3.42 at least) and a driveshaft. M6 have aluminum. Steel is fine but it's better to balance them if you go 3.42 or higher.
    MODS: A4 > M6 conversion, SC raptor hood, Vortech V9 G-Trim SQ, homemade water-alcohol injection
    DYNO: 410 RWHP, 417 TORQUE @ 5 PSI
    Feb 2006
    Alabama
    2001 Z 28
    Must have 4.10s are lower so much fun to drive around town
    Bowman, SC
    Crytal Red Tint Coat
    2013 SS Camaro Covertible
    Quote Originally Posted by RyansREDcamaroSS
    Check thes guys out! I am going to call them myself as soon as I get the money for the parts. They are in Charlotte, NC and it says on their site that they will convert an A4 to a 6 spd for $750.00 plus parts
    http://fbodymotorsports.com/
    2013 Camaro SS Convertible, Whipple Supercharger, Kooks Coated 1 7/8" headers, CAI Cold air induction
    http://s33.photobucket.com/user/Deea...?sort=3&page=1
  1. For Sale: 99 Z28 Automatic $4k
    By kevamg in forum Vehicles For Sale / Trade
    Last Post: 03-17-2012, 12:24 PM
  2. Help: automatic cam
    By WHITE TA in forum Internal Engine
    Last Post: 03-02-2012, 12:38 PM
  3. WTT for AUTOMATIC SS or WS6
    By noslognv6 in forum Vehicles For Sale / Trade
    Last Post: 06-01-2009, 04:51 AM
  4. M6 or Automatic?
    By Drift_King88 in forum GTO
    Last Post: 07-14-2007, 08:45 PM
  5. Automatic to Semi-automatic
    By larryndog in forum Automatic Transmission
    Last Post: 06-08-2007, 06:16 AM
