Results 1 to 10 of 10
Thread: Epoxy garage floor..
10-29-2009, 08:13 PM #1
Have any of you painted your garage floor with the epoxy/ paint kits?
If so, could you post some pictures maybe, and fill me in on somethings i may need to know about doing it myself.. I am moving into a house with a pretty big garage 25'x50' .. and I would like to know about how much will this cost me to cover the floors with a dark grey epoxy?
I am planning on doing quite a bit of work to the garage.. i'd like to make it into a hangout place.. tv, refrigerator, microwave, etc... along with a 50' long workbench on one of the walls.
10-29-2009, 08:16 PM #2
10-29-2009, 08:19 PM #3Just me
- Nov 2006
- Broken Arrow, OK
Here is another option for the floor I am considering:
http://www.swisstrax.com/
10-29-2009, 08:21 PM #4
yea it's a family house... my grandparents built the house back in the 50's, and my grandpa ALWAYS has to have a big garage.. but the downfall of it being a family owned home is that they have some of their stuff stored in there. My dads got his boat stored in there, along with my moms old 64 1/2 mustang, and my old project truck. I will get some pictures of it tomorrow when I go over there.. but yea.. i'm pretty sure i'l have to shell out quite a bit of money for the floor epoxy.
10-29-2009, 08:23 PM #5
I have seen that swisstrax before. It looks VERY nice, but I don't know if that would fall under my budget haha.
10-29-2009, 11:33 PM #6
We epoxied the floors in our shop at work. We got it from Sherwin-Williams, but i can't remember the price per gallon, I'll see if I can find out tomorrow. We first had to etch the floor using Muriatic acid, then hose it out and squegee it, let it dry over night, then roll it on the next morning, 2-3 coats. It's really pretty easy, and turns out real nice.
you'll probably need 2 gallons of M Acid - Pour 1/4 gallon in a 5-gallon bucket then fill bucket with water. dump the bucket on the floor and continue until the entire floor is covered. Let it sit about 10 mins. Squegee it out and repeat.
After 2nd acid etch, hose everything out and squegee, then let dry overnight.
The epoxy is 1-part paint, 1-part hardener, and I believe each 2-gallon mixture covers about 300 sq ft. You have to mix the paint 30 min before applying, and it's recommended to thin the first coat with paint thinner. Let the first coat dry 3-4 hrs, then apply 2nd coat (mix 30 mins beforehand, no paint thinner). We mixed it in the 5-gallon buckets and used brushes to get the edges really good first, then used 12-inch rollers screwed onto poles for the floor. Be sure to find helpers
We did 2 coats and it came out great. I think we spent about $150-$200 for 8 gallons of each (paint and hardener). I'll try to find out exactly how much and what it was called. Hope this helps, it's definetly worth it.
10-30-2009, 04:19 AM #7
There is a good discussion about floor epoxy in this thread: http://www.ls1.com/forums/showthread...ighlight=epoxy
10-30-2009, 05:34 AM #8
10-30-2009, 05:37 AM #9
10-30-2009, 06:39 AM #10
thanks for the info guys.. so if i have a floor zamboni, would you recommend i put the muratic acid down then buff over? or run the buffer, clean, then put the muratic acid down?
Garage Floor Coatings/Epoxy Reccomendations
By OreoLt1 in forum Almost Anything GoesReplies: 10Last Post: 05-31-2022, 03:47 PM -
Garage floor ?
By War Theory in forum Almost Anything GoesReplies: 8Last Post: 04-14-2016, 07:40 PM -
Garage Floor ideas
By knightryda01 in forum Almost Anything GoesReplies: 3Last Post: 10-01-2013, 08:52 AM -
UCoat It Epoxy Floor Coating Install - U-Coat-It Y
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 02-01-2010, 09:10 PM -
How To Apply Epoxy Coating To Your Garage Floor
By Ed Blown Vert in forum Almost Anything GoesReplies: 10Last Post: 05-19-2008, 09:45 AM
