Thread: 1969 Camaro
    Member sg5492's Avatar
    Leavenworth, Kansas
    99 SS Camaro Convertible
    1969 Camaro
    1969 Chevy Camaro Super Gas/Super Comp
    Description: 69 Camaro steel roof and quarters, glass front end, doors, decklid, and bumpers. Full round tube Alston Chassis, built in early 90’s, just updated with new coilovers and back brakes less than 50 passes ago. Front brakes have 0 passes. New BBC, Converter and Glide has 2 VERY easy passes on them. Car has been certified to go 8.50 @ 170mph. As of 06’ will have to add some more bars to make a 7.50 car again (up until 06’ it was always a 7.50 car), has a Funny Car Cage. Car should run 8.80’s @ low 150’s. Money winning car. Car is set up for a medium to large driver.
    Engine: 498 BBC, 14.5 : 1 Diamond pistons, Eagle 4.25 crank, Eagle 6” rods, worked steel heads, Lunati roller: (Part # 50222) .424-.722, 1050 gas Carb shop Dominator, Dart Intake Manifold, ATI Harmonic Balancer, stud girdles, and guide plates. Burlington Performance out of Raytown, MO built the motor.
    Fuel System: BG 280 pump, 5 gallon cell, braided line from cell to carb. 2 fuel pressure gauges.
    Oil & Water System: Aluminum radiator, Meziere electric water pump. High volume oil pump.
    Electrical System: Completely wired with white aircraft wires and connectors.
    ARC over head module 6 switch panel, MSD 7AL-2 box, crank trigger, electric shifter (Shifnoid) . MSD 2 step, MSD RPM activated switch, Line loc, Trans brake and Throttle stop. Biondo Mega 450. Two red top Optima batteries. Car is wired for alternator and head light.
    Gear Box: Hughes Power Glide with a 176 low gear and Turbo input shaft. (2 passes). Custom built Coan 5500 converter (2 passes) TCI trans shield, CSR flexplate shield. TCI flexplate Trans cooler.
    Final Drive: Mark Williams braced Ford 9”, Mark Williams center section with a Richmond Pro 488 gear. Mark Williams 40 spline gun drilled axels. New Mark Williams wheel studs, new Mark Williams drive stud washers (0 passes on studs and washers) Mark Williams drive shaft, and Mark Williams disc brakes on rear.
    Body: 69 Camaro original top and quarters. Removable glass doors, front end, and decklid. Car was painted bright red in early 90’s paint is still in good condition, Simpson Parachute, rear wing.
    Chassis: Full round tube Alston chassis, spindle mount front wheels, Strange front brakes with new Strange lightweight 10” slotted directional rotors offset 1.00” and new Strange brake pads (0 passes on rotors and pads), Strange struts, Mark Williams rear brakes (less than 50 passes) 4 link, anti roll, track locator, funny car cage. Wheelie bars. Has cups for Pro Jacks on Chassis. Koni coilovers.
    Interior: All AutoMeter Gauges, Liquid Filled Oil Pressure, Water Temp, Fuel Pressure with isolator. Voltmeter and Memory Tach are not filled. Low Oil Pressure Warning light. Autogage trans temp. Removable dash, steering wheel, seat, trans cover and section between tubs to access 4 link bars. Full Lexan car, Window net. Hurst Quart Stick with Shifnoid. CO2 bottle and mount.
    Tires and Wheels: New Weld Aluma Star 788 series version 2.0 (0 passes on wheels) front Hoosier 25.0 X 4.5 (50 Passes on front tires) 15X15 wheels with Hoosier 33.0 X 15.0 DO5 compound (0 Passes on slicks)
    Spares: Drag Lites Weld Wheels with Goodyear slicks 32.0 x 14.0 (40% left) and Goodyear front runners 24.0 x 5.0 (20% left), Strange lightweight 10” slotted directional rotors offset 1.50”
    Price: $34,900 turn key or $24,900 rolling (minus motor, trans, and converter) OBO Call 913-683-0362 MUST SELL!!!!
    All reasonable offers considered
    Can email more pics
    Waco Ky.
    2001 SS #3504
    WOW thats a nice car... minus the Snap On deacal on the dash..
    Leavenworth, Kansas
    Thanks!! I didn't put the Snap On deacal on the dash, the guy I bought the car from put it on there.
    Waco Ky.
    2001 SS #3504
    Cool.... Good luck with the sale.
    Leavenworth, Kansas
    NEW Price: $32,000 turn key or $22,000 rolling OBO
    What I do? SHines-IT's Avatar
    Jun 2009
    FL, USA
    1 (100%)
    2011 Prius
    Only if I could drive it everyday... Nice car, lol.
    402 Guru 402 Guru's Avatar
    Jan 2008
    las vegas
    02 Trans Am T-tops M6
    That is an awesome 69 Camaro good luck with the sale
  1. For Sale: 1969 Camaro
    By sg5492 in forum Vehicles For Sale / Trade
    Last Post: 02-08-2012, 01:36 PM
  2. 1969 Camaro
    By Z06-Goose in forum Showcar and Detailing
    Last Post: 11-05-2009, 06:20 AM
  3. 1969 Camaro RS
    Last Post: 03-07-2007, 02:20 AM
  4. looking for a 1969 z28 camaro
    By camaroguy1969 in forum Camaro / SS
    Last Post: 04-10-2006, 07:56 PM
  5. 1969 Camaro
    By Mr. CarelessAndImprudent in forum Vehicles For Sale / Trade
    Last Post: 10-03-2005, 08:10 PM
