Results 1 to 20 of 24
Thread: Wheel Studs
10-24-2009, 12:03 PM #1
Wheel Studs
Do you have to remove the rear axles to replace the wheel studs?
2010 Camaro
2006 GTO, LS2, 1 of 475
2009 Chevy Silverado
10-24-2009, 05:28 PM #2
Remove the ABS sensor & use the hole.
10-24-2009, 05:30 PM #3
Just noticed the GTO part... Might be the same ???
10-24-2009, 06:10 PM #4
10-24-2009, 06:48 PM #5
My long ones fit through. He could pull the sensor and stick the end of it through and see real quick.
10-24-2009, 11:58 PM #6
10-24-2009, 11:59 PM #7
10-25-2009, 03:04 AM #8
With the 3.25's, you will need the open hole lug nuts, so the stud will go through and stick out of the lug nut. Drag race aplication.
10-25-2009, 05:34 AM #9
10-25-2009, 05:55 AM #10
- Oct 2006
- St. Clair Shores. Michigan
If you have traction control then you have the ABS sensors on the backing plates. You should be able to remove the sensor and feed the Stud through the hole into the Hub.
But if you don't have traction control then your ABS sensor is on the rear center section. And you'll have to pull the axles to replace any studs longer then stock.Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
10-25-2009, 07:52 AM #11
- Thornton, CO
Why are you replacing the studs?
If it is to run drag wheels (like a ProStar) that is wide, you will want the 3.25's.
If you are replacing one broken one, just get a stock size replacement. I am sure I have one I can send you in that case.
10-25-2009, 08:05 AM #12
10-25-2009, 08:42 AM #13
- Thornton, CO
I would.
In order to legally pass tech with the ProStars you need the 3.25" studs.
Now...many techs will not check for this, but if they do, you may not pass.
10-25-2009, 08:49 AM #14
10-25-2009, 03:29 PM #15
- Thornton, CO
You want shank style lugs as well.
10-25-2009, 03:40 PM #16
Sure. I was thinking SST mags, 12mmx1.5
10-25-2009, 07:49 PM #17
- Thornton, CO
I got these....
http://www.summitracing.com/parts/MCG-63002/
*hopes summit is still a sponsor*
10-26-2009, 12:05 AM #18
10-26-2009, 03:57 AM #19
10-26-2009, 07:00 AM #20
Question: Rear Wheel Studs
By Brad(WS/Z0.6) in forum Wheels and TiresReplies: 4Last Post: 08-27-2009, 02:50 PM -
Wheel Studs
By ls1camino in forum DrivetrainReplies: 6Last Post: 03-11-2009, 02:52 PM -
which wheel studs
By LT1 > LS1 in forum DrivetrainReplies: 4Last Post: 09-17-2008, 01:39 PM -
wheel studs
By kyemt in forum GTOReplies: 9Last Post: 12-09-2007, 07:38 PM -
Wheel Studs>>Help
By mikriman1 in forum Wheels and TiresReplies: 3Last Post: 04-23-2006, 05:13 PM
