    SATX
    2000 Trans Am
    how do I delete Rear O2's with HPT
    I am new to Tuner, the past couple of nights, ive been going through it like a madd man, But I dont know where to begin. How do I delete the Rear O2's?
    Member Larry's Avatar
    Sugar Land, Texas
    2017 Z06
    Disable these codes in your editor engine diagnostics DTCs:
    P0036 H02S Heater Control Circuit Bank 1 Sensor 2
    P0054 H02S Heater Resistance Bank 1 Sensor 2
    P0056 H02S Heater Circuit Bank 2 Sensor 2
    P0060 H02S Heater Resistance Bank 2 Sensor 2
    P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2
    P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
    P0140 HO2S Circuit Insufficiency Activity Bank 1 Sensor 2
    P0141 HO2S Heater Circuit Bank 1 Sensor 2
    P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2
    P0158 HO2S Circuit High Voltage Bank 2 Sensor 2
    P0160 HO2S Circuit Insufficiency Activity Bank 2 Sensor 2
    P0161 HO2S Heater Circuit Bank 2 Sensor 2
    P0420 Catalyst System Efficiency below threshold Bank 1
    P0430 Catalyst System Efficiency below threshold Bank 2
    SATX
    2000 Trans Am
    Thank you, do I Uncheck the box, and then I choose the 3 No error reported from the dropdown box right? thank you
    Sugar Land, Texas
    2017 Z06
    For me it worked with it checked and using 3 no error reported. Not sure what happens with each unchecked.
    Edited error above. I mentioned scanner previously.
    Member Sweet Chops's Avatar
    Manitowoc, WI
    Hugger Orange
    1999 Camaro Z28
    SATX
    2000 Trans Am
    thank you!
    I have a problem with my Y though, but I will post it on General
  1. Delete Rear O2 Sensors?
    By Speed Bump in forum General Help
    Last Post: 09-21-2009, 09:36 AM
  2. rear o2 delete?
    By slpdablueZ28 in forum Computer & Tuning
    Last Post: 11-08-2008, 07:22 PM
  3. Rear O2 Delete
    By TOWAR in forum General Help
    Last Post: 10-23-2007, 10:23 AM
  4. Rear Seat Delete
    By SStriker in forum Appearance Section
    Last Post: 07-01-2007, 10:50 PM
  5. Gto Rear Wing Delete
    By Raoul-Duke in forum GTO
    Last Post: 05-09-2007, 04:39 PM
