Results 1 to 18 of 18
02-10-2006, 10:55 PM #1
- Sep 2005
- New York, NY
Collectors Edition Yellow- 2002 Pontiac Trans AM WS6
Should i turbo or supercharge my 02 WS6??
In the market for either a Twin Turbo setup from HP Perf or get a nice supercharger... I'm looking for some nice HP numbers... Around 700 and i want to be able to raise it if i need to... It would be on my DD so i'm looking for some suggestions on what i shoudl go with!!
02-11-2006, 05:14 AM #2
- east stroudsburg, pa and middlesex, nj
black- 2001 Camaro SS M6
what is your bidget to spend. that would be kinda hard to get with a supercharger, unless you get a stroker motor with forged internals on a supercharger. That would be a easiler goal with twin turbos..go over to ls1tech..two shops just made tt kits that put down around that at the wheels, but both where on forged motors..and both were iron blocks I believe.
02-11-2006, 09:04 AM #3
- Aurora Colorado
700 on a DD.....oh what fun.
Either way you are going to go with a full forged setup. To reach 700 and have it last. So in that case "I" would go with a blower vs a TT. And a well built motor with the right heads and cam, I would think it would be no problem.2001 WS6 Artic White, M6,Procharger D1SC, Custom air box for use of stock filter and location, and ram air function.ATI Superdampner 8 rib drive 540.3Hp 533.8Tq @ 9psi,
02-11-2006, 12:24 PM #4
- Sep 2005
- New York, NY
Yea cuz i was actually looking at the D1SC pro charger and i saw that it supports 950HP at 35PSI...even though i would never go that high but atleast i have a big ceiling.... I heard that supercharging was better then TT..... The TT setup that i've seen goes for $10K and the D1SC goes for $6K and change.....
I think the D1SC would be the best bang for the buck in comparison with the TT kit...
02-12-2006, 03:54 AM #5
- Oct 2005
- Glen Allen, VA
Black- 2001 Camaro SS Vert.
You will not see 700HP for $6k. You will need either SC or Turbo plus heads, cam, headers, exhaust, etc. Then you will need clutch, 12 bolt, etc.
02-12-2006, 05:32 AM #6
- Retired Outlaw Sum Bitch
Try around 15K for what you are talking about.....
02-12-2006, 12:13 PM #7
- Sep 2005
- New York, NY
Originally Posted by Sarge
02-12-2006, 12:14 PM #8
- Sep 2005
- New York, NY
Originally Posted by clemsondave
02-21-2006, 02:49 AM #9
We are currently at 688 rwhp and 697 ft lbs of torque, with a D-1SC at 14 psi in a Trans-Am on my Mustang Chassis Dyno, this would be much higher on an unloaded type of chassis dyno, such as a DynoJet.
http://www.exoticperformanceplus.com...Car.php?car=27 Link to the car.
We built a 382 ci stroker engine for it, and have a mild Lingenfelter GT2-3 camshaft in it, along with Patriot Performance Stage 3 LQ9 heads. BobCheck out our huge website at http://www.exoticperformanceplus.com
Your Midwest Moser Specialist - We price match!
Your Midwest ATI ProCharger Specialist - We only sell the best supercharger, the ATI ProCharger! We price match! 260 244-4808
02-21-2006, 06:02 AM #10
even if you have head's already, you may need new heads to lower the compression of your engine to run more than 7psi. either new large chamber heads or lower compression pistons or shorten the stroke and lose cubes along with compression<i doubt you'll do that. you may want a new cam too if there's a lot of overlap on your current one cuz you dont want all the air forced in going out of the exhaust valve after the exhaust.
I think you gotta think about the whole picture. first of all if you want to be able to change your boost later then supercharging is better cuz you can always change pulleys and run low boost now and drop compression later and run more boost later with another pulley.
or if you want to go faster now (at the track) you can get a 12 bolt (with 4.10 or 4.11's and slicks or drag radials since you have a clutch already and drop from higher rpms and you'll run faster since you already have good power assuming you have a good set of hand ported heads and cam and a good dyno tune with all that and your headers. and get the blower later.
I would recommend getting the rear axle first and good tires, I personally would get nitto 555rII or something like that that improves handling too not just drag but that's me. i would recomend this cuz you still are not taking advantage of the power you have so why add more power? you'll never get it to the ground anyway. and when you do you'll snap your rear. i would also get at least some global west rod ended lca's, rod ended panhard bar, and of course sub frame connectors if you dont have those yet.
overall (unless you have a lot of suspension mods) your car as a whole seems to me that it lacks tires, rear, suspention, sub frames, etc. mods more than it lacks power. who wants a car that cant move forward cuz it'll just spin the tires and when it does get up to speed can't turn or stop that good any way?
Just my opinion, good luck.
02-25-2006, 06:06 AM #11
- Sep 2005
- New York, NY
Originally Posted by csteingraber
Bulletproof Performance
2002 Trans AM WS6 M6 Collectors EditionLSX 427 F-1R Procharged Build Underway
Estimated Finish Date: Summer 2012-2013
02-25-2006, 07:37 AM #12
- Oct 2005
- Glen Allen, VA
I'd go with D1SC. Correct me if I'm wrong here guys, but he won't be happy with the 4.10 gears and FI, right? It will rev too quickly.
02-25-2006, 07:50 AM #13
- Aurora Colorado
Procharger D1SC great choice!
Corret 3.73,s are a good choice over 4.10,s for F/I
02-25-2006, 12:07 PM #14
- Sep 2005
- New York, NY
Not a problem i could just change the gears once i switch to FI but thanks for the heads up..!!
02-25-2006, 03:19 PM #15
- Oct 2005
- Glen Allen, VA
Should be smokin! Keep us updated. I am about a month out from a D1SC.
02-26-2006, 09:33 AM #16
- Sep 2005
- New York, NY
Im aiming for over the summer.......Time to start savin pennies!!!
03-01-2006, 08:11 PM #17
if you swap gears you may want to put it towards a 12 bold instead so you're not spending more on the stock rear. but i know that the SC is expensive enough so i dont know if that is economically an option.
i hope to be able to buy a procharger too someday. Good luck with the car.
Oh, and i read something somewhere that you should get the upgraded pulley system with the procharger so the belt doesnt slip.
03-03-2006, 05:52 PM #18BLOWN_70_CAMAROGuest
For the rear i would go with a Ford 9" and 3.89 gear or 4.10 you have a stick right so you can very your launch and shift it into 6th gear if its a 6 speed and you should be good ok for RPM's
Question: Can u turbo/supercharge/or juice a 346cu" w/ a MS4 cam
By Eganslp in forum Forced InductionReplies: 9Last Post: 12-25-2010, 06:31 PM -
Question: to supercharge or not?
By transamgirl89 in forum V6Replies: 38Last Post: 11-17-2010, 08:04 PM -
Supercharge or turbo?
By dennis ss in forum Forced InductionReplies: 28Last Post: 06-22-2010, 08:19 AM -
Question: turbo or supercharge?
By kitty1987 in forum Forced InductionReplies: 14Last Post: 08-28-2008, 03:04 PM -
supercharge or h/c
By stangslayer98 in forum Firebird / WS6Replies: 13Last Post: 05-21-2008, 01:53 PM
