Results 1 to 14 of 14
Thread: Ratio?
    Junior Member Crusty's Avatar
    Oct 2009
    Brookville, Indiana
    2002 ws6, 70 Road Runner
    Ratio?
    What rear end ratio are usually in a 2002 ws6? Mine has no tag..My 2002 z28 had 2.73's and my T/A feels alot lower than that to me.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    I think I remember you saying in another thread you are a M6 so it would be 3.42
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    2.73 and 3.27 on automatics,3.42 on manual as mentioned above.
    Oct 2009
    Brookville, Indiana
    Automatic...
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    i would guess 3.27,that's how my 02 ws-6 is optioned.
    Oct 2009
    Brookville, Indiana
    Cool thanks guys. Didnt want to pull the cover off. lol Wonder if i put a 3.42 in it if it would that big of difference at the track. I drive it everyday so i dont wanna go to deep. Just a thought
    Rule of thumb is 373 for A4 and 411 for M6.
    Gears really depend on what your future plans on for the car.
    Omaha, NE
    2000 Z28 Camaro
    Check your door codes. No sense in guessing. Also, what are your RPMS at 60mph. Another easy way to tell if you are on stock tires.
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    there is a rpo code on the inside drivers door that will tell you exactly what gear your t/a was born with,i just can't remember it,probably can be found in the drivetrain tech section.i am gonna put a 3.42 in mine in the near future.
    Oct 2009
    Brookville, Indiana
    Cool i will look in the morning and check rpms on the way to work.. I cant remember for sure..but I do have stock tires so far.
    Oct 2009
    Brookville, Indiana
    1800 rpms at 60 mph. Called the VIN in to dealer they said 3.23 so problem solved THanks
    ^^ Dealer is correct, the auto should have 3.23's. On your driver door are the RPO codes for your car. You can decode most of them at this site: http://www.marshu.com/ws6-firebird-c...codes-2000.php If I recall, GU5 is the code for a 3.23 rear axle.
    Oct 2009
    Brookville, Indiana
    Cool i will check it out...Thanks
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    All Auto Equipped WS6's have 3.23 gears
    It was a mandatory extra cost option with the WS6 Pkg
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
  1. Question: a/f ratio
    By mark21742 in forum Computer & Tuning
    Last Post: 02-12-2009, 03:29 PM
  2. Compression Ratio
    By Bouvers in forum Internal Engine
    Last Post: 01-12-2009, 01:56 PM
  3. steering ratio different on my 95 LT1 than my LS1?
    By krese in forum Firebird / WS6
    Last Post: 04-08-2008, 05:01 PM
  4. Rear End Ratio???
    By bkdmnd in forum Drivetrain
    Last Post: 03-31-2007, 04:15 AM
  5. HP to Time ratio
    By BanditTransAm in forum Firebird / WS6
    Last Post: 02-28-2007, 05:24 PM
