Results 1 to 20 of 20
    Question really wierd clunk...
    i have a clunk coming from the drivers side near the strut... the thing is it ONLY clunnks when it's raining out or the roads are really wet... i checked my swaybar bushings and they seemed ok but they are a bit worn...any one got any ideas what it could be and why it only clunks when it's wet out... am i trying to look to hard at something that is obvious???
    TEXAS... U mad?
    Black / Stryker Blue
    2K WS.6/ 2K9 G8GT
    What makes it clunk.... bumps, turning....
    bumps... small jerks via un even acceleration... going around corners... it's really odd... i can't put my finger on it...
    Member pewterz55's Avatar
    Jul 2009
    chicago
    light pewter metallic
    1999 z28
    i wish i could help ya man. i got the same problem. except it does it all the time not only in the rain
    It's rained and been wet out all year in the northeast!
    I have no idea what a "wet only clunk" could be, it just doesn't make sense that moisture would cause the noise you hear. I think the only thing water would have an affect on is your brakes. On my Ranger, the back drums will grab when wet, but that simply does not apply to discs.
    Subscribed to learn something new...
    it's not the brakes... i thought it was a loose caliper at first... i'll see if i can get some video the next crappy day we got...
    Shouldn't have to wait long at all for that to happen.
    not with this junky weather... the only thing i can possibly think off is that when i put the srpings on my front struts that i didn't tighten the bolt enough and that it might have a little give or something... but it jsut doen'st make sense that it would only do it when it's wet out...
    Just for kicks, next time it rains lift the hood and bounce the car on its suspension sitting in your driveway. Who knows, maybe you'll get a noise you can pinpoint.
    Tie rod end??
    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    ball joint?
    Oct 2009
    pewter
    99 trans am
    control arm bushing?
    Tie rod end??
    nope... i just replaced mine with ones with grease fittings... brand new... also cheked the bags to make sure they were full and they are... i did that when i replaced the power steering rack...
    Henryetta/Tulsa Oklahoma
    2016 Camaro SS - Summit
    2001 Trans Am WS6 - NBM
    I think you made this thread just to boost your post count
    On a serious note, I still get that clunk every once in a while, haven't really paid attention to see if it's only when it's wet out, got 174k on the clock, I've replaced shocks all the way around, checked all my bushings, so I don't know what it could be either...but now I'm getting a clunk, more of a click clack, in the back when I hit bumps or holes, so I've got bigger problems to worry about
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I'm gonna go with the strut mount. Also check your front sway bar as it may be shifted either to the right or left. And check the endlinks to make sure one is not tightened more than the other.
    scheisse!!! time to put my car on the lift...
    Broken Arrow, Ok
    2000 Z28
    Upper or Lower control arm bushings. The strut itself.. Is the spring sitting correct?
    yyeah... the spring is sitting right... i put in KYB agx shoucks a while back... i'll check the bushings this week end...
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    i know this might be far fetched..but i know you have aftermarket headers and Y .....
    my car does the same thing..however not only when wet..but the headers are making contact with the frame and or the lower control arm mounting area .....i need to get that fixed really soon..but for shits and giggles and to be nice to be..check your tolerances around that area.
    Member TRANS-DAD's Avatar
    PASADENA,TEXAS
    BLACK
    2001 T/A VERT.
    My friends car was doing the same thing,not when raining but just random & it was driver side shock/strut nut on top!
  1. clunk clunk clunk
    By zmandan in forum Drivetrain
    Last Post: 01-10-2012, 11:14 AM
  2. clunk noise
    By travz28 in forum Suspension and Handling
    Last Post: 11-11-2010, 02:33 PM
  3. This clunk is making my brain clunk....
    By silversho89 in forum Drivetrain
    Last Post: 04-22-2009, 03:51 AM
  4. Had a wierd dream and wierd day..
    By JoshieDoom in forum Almost Anything Goes
    Last Post: 08-27-2008, 06:30 AM
  5. loud clunk
    By 01outlaw in forum Drivetrain
    Last Post: 02-28-2007, 05:48 AM
