Results 1 to 18 of 18
Thread: Technical Information
10-16-2009, 04:59 PM #1Junior Member
- Oct 2009
- Ga
white- 1998 camaro z28
When I drive my car hard, my oil pressure takes a dive. Any suggestions?
10-16-2009, 05:17 PM #2O U 8 1 2
- Nov 1999
- over here...
i'll be kind and move this thread even though you didn't read the RULES!!!
10-16-2009, 05:20 PM #3
Have you checked it with an aftermarket pressure gauge? What sort of numbers are you seeing on the gauge?
10-16-2009, 05:39 PM #4
yeah, what kinda pressures are you seeing. Normally oil pressure should go up with rpm's and not down.
10-16-2009, 06:39 PM #5
probably a bad/leaking sending unit
10-16-2009, 06:48 PM #6
10-17-2009, 01:39 PM #7Junior Member
- Oct 2009
- Ga
the engine has been replaced with a 04 ls6 crate it now has 98k miles on it.the oil pressure gauge dips down to about 25 psi during desselaration after a hard run not during the run. oil pressure stays between 40 60psi during the run and normal driving
10-17-2009, 08:35 PM #8
10-17-2009, 08:41 PM #9Slow'er'Ass
- Thornton, CO
Mine does this as well.
It is normally a little low on oil when it does.
10-17-2009, 08:46 PM #10
10-17-2009, 09:55 PM #11Junior Member
- Oct 2009
- Ga
the gauge reads 40 to 60 at wot pressure only dips when u come to a stop or almost stopped no noise or other problems stills hauls ass at 12.56 in the quarter
10-17-2009, 10:00 PM #12
10-17-2009, 10:00 PM #13Junior Member
- Oct 2009
- Ga
10-18-2009, 05:37 AM #14
10-18-2009, 06:03 AM #15┌∩┐(◕_◕)┌∩┐
wouldn't want to fight them!
10-18-2009, 07:38 AM #16
10-18-2009, 04:22 PM #17Bone it like you own it
- Sep 2005
- TEXAS... U mad?
Black / Stryker Blue- 2K WS.6/ 2K9 G8GT
I would verify with a mechanical gauge first....
10-18-2009, 05:50 PM #18
Technical Articles -- Any Requests?
By pajeff02 in forum Firebird / WS6Replies: 39Last Post: 08-15-2011, 06:29 PM -
Question: Technical drawings LS7 or Cad Model
By maestro69 in forum Internal EngineReplies: 0Last Post: 03-08-2008, 06:37 AM -
I need technical info!!! LS1-LS2
By dvdslw in forum General HelpReplies: 2Last Post: 08-19-2007, 11:36 AM -
Technical help posting pics
By Huskerz1 in forum Almost Anything GoesReplies: 1Last Post: 03-07-2007, 11:13 AM
