Results 1 to 20 of 26
Thread: Royal Purple?
10-15-2009, 05:41 PM #1
Royal Purple?
Does anyone run royal purple oil / and do u see any real benifits from it. Some say u can increase ur hp slightly just by using royal purple fluids?
10-15-2009, 05:53 PM #2Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
Don't use Royal Purple...some of the biggest crap ever made, along with Weapon X Spark Plugs.
Sarge made some threads awhile ago with studies done with the top 10 oils and Royal Purple did the worst in almost all of the tests (heat disipation and wear factor). Do a search and you should find them.
10-15-2009, 06:23 PM #3
Royal Purple also took a hit for false advertising not too long ago: http://www.corvetteactioncenter.com/...vertising.html
10-15-2009, 07:41 PM #4
royal purp is way overrated. stick with mobil 1 5-30. but i will tell you they make really good diff fluid.
10-15-2009, 07:51 PM #5
royal purple
Mobil 1
10-15-2009, 08:39 PM #6Bone it like you own it
- Sep 2005
- TEXAS... U mad?
Black / Stryker Blue- 2K WS.6/ 2K9 G8GT
Royal Purple = Aunt Jemima
10-15-2009, 09:04 PM #7Slow'er'Ass
- Thornton, CO
Mobil 1 is fine. But overpriced.
Pennzoil Platinum 10w-30 is the best cheaper off-the-shelf synthetic oil for our cars.
$20 for 5 quarts at Wal-Mart. I think the one by my place actually had it down to $19 last I saw.
10-15-2009, 09:18 PM #8
10-15-2009, 11:48 PM #9
10-15-2009, 11:57 PM #10
10-15-2009, 11:59 PM #11
10-15-2009, 11:59 PM #12
I've run 10w-30 the entire life of my car
The 5w-30 is more then likely to get a higher MPG out of the meaty LS1 from GM
10-16-2009, 12:00 AM #13
10-16-2009, 12:00 AM #14
Last time I ran RP was 2 years ago.....then went to Pennzoil Plat and now Amsoil after the H/C
10-16-2009, 12:00 AM #15
10-16-2009, 02:01 AM #16
Same thickness...
Sarge has covered this before as have I. 5W-30 and 10W-30 are both the SAME thickness at operating temp. The difference, 5W is a little less thick at cold engine start-up than 10W.
Personally, I use 0W-30 so that I get optimum oil flow at cold engine start-up while still protecting as well as 5W-30 or 10W-30 motor oils when the engine is warmed up and under load.
Let me put it this way, the 30 at the end of 0W-30, 5W-30, and 10W-30 means that all three oils have the SAME thickness or viscosity at engine operating temp.
CompSyn
10-16-2009, 04:02 AM #17
I have used Royal Purple exclusivly in both my 01 Z28 (Sara), and my 04 Tahoe, and have had no issues whatsoever. I purchased 5 cases when the price was around $4.30 a quart, and I have enough left for 2 more oil changes. The price is way up now, around $8 + a quart, so I am planning to change brands of oil. I am going to try the new Castrol "Edge", and keep the same weight @ 10W30.
I change my oil every 10K.
SteveC
10-16-2009, 04:23 AM #18
10-16-2009, 05:48 AM #19Alabama Member
- Jan 2008
- heart of dixie
06 Jeep Grand Cherokee.- 02 superchipsZ28 M6(sold)
I RAN the purple 10w-40 till i sold the z, never any issues. changed every 5000 ran a k&n oil filter also.
10-16-2009, 05:55 AM #20King 0f n00bz
- Jan 2006
- Shepherd, Michigan
Pennzoil plat or amsoil...period do not differentiate or even think anything else
2010 Royal Purple Giveaway - Royal Shop Talk
By Ed Blown Vert in forum Camaro / SSReplies: 1Last Post: 06-10-2010, 03:33 AM -
Royal Purple
By Mr. Luos in forum Almost Anything GoesReplies: 62Last Post: 08-01-2008, 10:48 AM -
royal purple vs pp
By slpcamaro in forum General HelpReplies: 32Last Post: 07-24-2008, 04:59 AM -
Royal Purple
By MavrickCJH in forum Internal EngineReplies: 12Last Post: 10-16-2006, 04:59 AM -
Where to buy Royal Purple?
By Blown Interceptor in forum Western MembersReplies: 11Last Post: 06-19-2006, 06:58 PM
