Results 1 to 13 of 13
10-15-2009, 02:44 PM #1Junior Member
- Jul 2009
- Cape Coral, Florida
Blue/Black- 2002 Camaro SS
Suspension "whack!" when hard cornering.
I noticed this while on a track road course first, a fairly loud noise from the rear of the when cornering hard.
I jacked up the rear end, and there was a little play in the axle bearings at the wheels, and I blamed it on that. I had the axle bearings replaced, but I still get the noise when cornering hard, even on the street.
I think it may be the Panhard bar hitting the exhaust system (which is not stock). It was rattling when starting up and backing out of the driveway and I put up with that, but this sounds dangerous.
Does anyone have any input on what might be the problem or how to correct it?
Steve Nix
10-27-2009, 12:27 AM #2Senior Member
- May 2009
- Toronto
SOM- 2002 SS
happening turning a certain direction? Definitely sounds like the exhaust
11-01-2009, 04:18 PM #3Junior Member
- Jul 2009
Both directions....
It happens when turning left or right, at high speed (track conditions). It is a little worse turning right.
Steve
11-01-2009, 08:21 PM #4Senior Member
- Jun 2008
- Rochester, NY Rochesterracing.com
- 2000 Camaro B4C
yeah id life the car up in the air and rattle around the exhaust just to make sure that its not hitting. sounds like the exhaust to me especially because it happens turning both directions
2000 B4C Special Service Package Z28 - Kooks 1&7/8 Stepped 2'' - TSP Torquer V.2 - FAST 92/92 - BDR 4000 Conveter - Xtreme Trans Stage II - Full UMI Suspension - Pacesetter LT's - Comp Drag Shocks - Magnaflow - Cutout - ZO6 MAF - FTP LID - Street Tuned -
11-01-2009, 08:28 PM #5
I'd say its a panhard bar problem.. Mine makes a clunking noise when i hit a bump in the road or a bad railroad track, and on a sharp turn.. and i'm pretty sure mine is caused by the panhard bar..
I'm afraid of driving my car anymore until I get that replaced.. I don't want to do any other damage
11-02-2009, 11:07 AM #6Junior Member
- Jul 2009
Exhaust system adjusted....
I went to a muffler shop, and they thought the problem was the whole exhaust pipe was just too low, and hitting on the panhard bar.
Since the exhaust was definitely a little low between the front & rear wheels, and was hitting the panhard bar in the rear, they adjusted the whole system slightly higher.
I still hear some rattling on start up and back up from the garage but have not been able to duplicate the "whack" of what I think was the exhaust pipe hitting the panhard bar. I have not had the real test yet of being on the track, but haven't been able to make it happen on the street yet, which is good!
Thanks for the suggestions, I appreciate it.
Steve Nix
11-10-2009, 11:34 PM #7Senior Member
- May 2009
- college station, tx
sold: 1999 firebird- 1998 Trans Am
mine does this too, i'll have to take a look see to make sure im not doing damage
11-10-2009, 11:36 PM #8
11-10-2009, 11:47 PM #9
11-11-2009, 12:36 PM #10
Check the rubber in the right rear exhaust hanger mount. Over time it wears creating slack in the mount. Also look for a shiny area on the over axle pipe to see if the axle is contacting the pipe.
11-16-2009, 11:00 AM #11
When I had the same problem it turned out to be a broken bolt on the tranny at the tranny mount.
The car 'banged' with every high speed corner at a road race track.
11-18-2009, 03:40 PM #12Junior Member
- Jul 2009
Thanks, I'll check that out....
I'll have a chance this weekend to get it up on jackstands and check that out. I have my doubts, because they checked it out on a lift when they adjusted the exhaust system, and it seems to be coming from further back, but I'll pay special attention to the tranny mount.
Thanks again for the suggestion.
11-18-2009, 03:45 PM #13
PMSNBC Dolt: "Hard-Worker" Could have Wacist Context (vid)..
By wileyCoyote in forum Political / Debate ForumReplies: 3Last Post: 10-28-2015, 06:53 PM -
Hard Left in Knots over "Wacist" Prism of "Cat Call" vid
By wileyCoyote in forum Political / Debate ForumReplies: 0Last Post: 10-31-2014, 04:07 PM -
Help: 3800 3.8L V-6 "hard start"
By 2000dreambird in forum General HelpReplies: 14Last Post: 09-14-2014, 06:06 AM -
IRS claims more "hard-drive crashes" have occurred
By theorangeguy in forum Political / Debate ForumReplies: 2Last Post: 07-22-2014, 09:43 AM -
"Live Free or Die Hard" anyone ????
By Speedy_Gonzales in forum Almost Anything GoesReplies: 2Last Post: 08-23-2007, 11:27 AM
