Results 1 to 15 of 15
10-13-2009, 11:19 PM #1Member
- Sep 2008
- Atlanta, GA,Ft.Walton Bch,FL
- Blog Entries
- 1
silver- 99 ws6
what doe's a dremal metal grinder look like?
I plan on grinding on the K member a little to cleanace the LTs better.
looked at Dremal site found this
http://www.dremel.com/en-us/attachme...%26+Sharpening
I have the intire kit however only used the sanding drum an the cut off wheel
can some show me what a metal grinder bit looks like or maybe a part #.
Thankscam-LTs-FAST78-Susp.-Rims
10-13-2009, 11:25 PM #2Turgid Member
- Jun 2009
- Hollywood, Florida by way of Da' Burgh
Impulse Blurr- 2004 GTO
This is a carbide rasp/burr. They also have some that are made out of stone
10-13-2009, 11:44 PM #3Member
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
bit
I know I have the stone (? stone won't cut the K member metal right?) type I'll look to see if I have the rasp, bur
don't think it was included in my 400 kit.
Thanks
10-14-2009, 01:00 AM #4Turgid Member
- Jun 2009
They come in different sizes and shapes. The one pictured is an acorn style. You might have to go to a "REAL" tool store to purchase one, I did. HomoDepo, Lowes ect. has a pretty limited variety of bits.
10-15-2009, 01:45 AM #5Member
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
real tool store?
I looked in my dremel kit mainly just a bunch of sanding drums, no Rasp/bur type grinder.
I've never used the flex attachment maybe this w/ the cut off wheel will enable me to get the proper angle to cut the K-member?
what is considered a real tool store any recommendations would help.
here's what the local Lowes has think it will grind the k-member?
http://www.lowes.com/lowes/lkn?actio...-03&lpage=none
Thanks for you adviceLast edited by qwik219d9; 10-15-2009 at 02:09 AM.
10-15-2009, 02:47 AM #6Turgid Member
- Jun 2009
I believe that bit will do the job. I use a die-grinder with larger attachments. That dremel might be slow going but then again I don't know what size the dremel is. That bit should do fine though. I hope you aren't taking too much off of the member or you will run into structural issues. I would steer clear of anything that could be deemed a folded seem. Only a little off of flat edges.
10-15-2009, 04:17 AM #7Member
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
exhaust contacting body
I have another thread on this issue.
the dremel I have is there best one 400xpr. looked again and in the grinding box w/ sanding drums & stone grinders there's a simiarl bit to the one above there's a green dot next to it.
when first installed the LTs driver side contacted the steering shaft had to dimple the LT a little then ended up removing the steering shaft and grinded it down some I'm thinking this new differnt nosie is the collector hitting the floor.
I have'nt inspected it yet (lots of rain) if real close to floor maybe I can try a small crow bar and bend the LT down, I've also read people using a BFH on the floor. my LT collecter is a flanged type not slip fit this will be the first place I check. would prefer to grind on the collector than beat on the floor.
http://carphotos.cardomain.com/ride_...0034_large.jpg
driver side always been close to the K-member.
? how close (in space) is to close?
maybe from the few times car bottomed out caused this?
ThanksLast edited by qwik219d9; 10-15-2009 at 04:30 AM.
10-15-2009, 02:22 PM #8Turgid Member
- Jun 2009
I'm not really down with all of this cutting of pieces that are meant to support weight. It sounds kind of hammer mechanic to me. I saw your other thread FYI. Under what conditions are the contact being made? There may be another safer route. I personally would manipulate a non load bearing part.
10-16-2009, 03:10 PM #9Senior Member
- Apr 2008
- Madison, WI
This is what I use. Its an air powered die grinder with a metal grinding bit.
10-18-2009, 08:13 AM #10Member
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
inspected exhaust
I crawled under the car and my observations where it's not the K-member or the collectors hitting floor plently of clearance.
maybe it's the motor mounts?
I've read that alot of folks have the Y-pipe hitting the trans mount looks like I need to put car on lift for a real close inspection.
weird sounds like the noise is under my feet.
Thanks
10-18-2009, 11:23 AM #11Senior Member
- Apr 2008
- Madison, WI
maybe you have a bad trans mount or torque arm mount causing your clunk. Did it start happening right after you header install?
10-18-2009, 08:42 PM #12Bone it like you own it
- Sep 2005
- TEXAS... U mad?
Black / Stryker Blue- 2K WS.6/ 2K9 G8GT
Is car auto or stick?
10-22-2009, 09:10 PM #13
I would rule out that trans mount...pretty common for those to go out. Like was said though, what conditions does it hit under? The Y will usually hit right under the driver where it makes the bend to join the other side.
10-23-2009, 05:16 AM #14Member
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
1.exhaust contacting body while at idel it's not all the time I'd say rarely however I can diffenitly feel and hear it seans like it's orginateing from around the driver side.
2.I've replaced a trans. rubber mount (w/ OME) and when it went bad w/ only a 1/2" tear it was very noticable w/ vibration.
3.it's not a clunk it's more of a shaking & hitting.
4. as far as the torque arm mount I have a good Eldobrock TA w/ nice poly trans. mount bushing BTW it made this exact same noise w/ the stock exhaust.
5. I have a custom made Y-pipe (from LT collector 3" reducer into 2.5" tubeing into a flowmaster merge collector then flanged into my Hooker cat back) and it appears to have plenty of clearance, looks like I have to put it on a lift and inspect real closely.
6. car is auto.
7.The Y will usually hit right under the driver where it makes the bend to join the other side.
I will inspect this area real close. and take a few images.
I am convinced this exhaust contacting the body is the cause of my pinging at wide open throttle. I've tryed to be as detailed as possiable.
Maybe this thread can be combined w/ other related thread exhaust contacting body) thread in the general section.
Thanks Guy's for the surrportLast edited by qwik219d9; 10-23-2009 at 05:30 AM.
10-25-2009, 05:24 AM #15Member
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
exhaust inspection results
took car to a muffler shop. Man did'nt want to inspect exhaust w/ my ORY
or bend anything.
I asked nicely and he did inspect around the motor mounts and trans. brace nice cleanance on both.
man said the over the axel catback U clamp was touching the heat shield
this U clamp may need adjusting or replaceing w/ a band clamp.
this blows my mind because I feel and hear it under my feet.
ThanksLast edited by qwik219d9; 10-25-2009 at 05:30 AM.
Ron Fournier: Metal Fabricator - Metal Man
By Ed Blown Vert in forum Almost Anything GoesReplies: 1Last Post: 03-03-2011, 12:47 PM -
help--Metal in Metal chatter- need homemade gasket
By jrc1122 in forum Manual TransmissionReplies: 2Last Post: 06-03-2008, 03:30 AM -
Kobalt Mini Die Grinder/Polisher
By GULLETT17 in forum ToolsReplies: 29Last Post: 04-22-2008, 12:20 PM -
sand blaster and die grinder questions
By 0rion in forum ToolsReplies: 2Last Post: 02-11-2008, 02:30 PM -
Istalled new pushrods, now new metal on metal noise
By brokenls1 in forum Internal EngineReplies: 0Last Post: 02-02-2006, 03:29 PM
