Thread: MAF replacement
10-13-2009, 12:09 PM #1
MAF replacement
I need to replace my Mass Air Flow Sensor on my 1999 Firebird i only have the 3.8 v6 im lookin to spend 200$ on one so any body have any ideas on a good replacment over my stock one which is goin out thanks for the help.
10-13-2009, 12:32 PM #2
10-13-2009, 12:56 PM #3Senior Member
- Jul 2005
- Jacksonville, FL
What makes you think the MAF is going out? What code(s) is it throwing?
10-14-2009, 09:46 AM #4
i was up at the shop couple days ago havin a new fuel filter put on an the guy workin on my car said hed scan my car see why the SES light is on so he did an it said my MAF is goin bad i guess its suppose to put out 4.00 lbs of air if i heard him right and what the scanner was reading was it was puttin out 0.14 lbs so im needin a new one
10-15-2009, 04:18 PM #5
Get a stocker on EBay or the junk yard unless you plan on doing any major upgrades in the future. The stock unit should handle any aftermarket cams and what not you could put in a 6. No point in spending the extra bucks on aftermarket.
10-15-2009, 05:04 PM #6
did you try cleaning it first with MAF cleaner before replacing?
10-15-2009, 05:08 PM #7
+1 This is probably the issue. There are lots of reports on here of guys having problems that clear right up once the MAF is cleaned. If you do replace it, resist the urge to splurge for aftermarket hype and go with a stock GM MAF. You can look it up at the GM Parts Direct website by hitting the sponsor link at the top of the page.
10-16-2009, 04:26 AM #8Junior Member
- Apr 2008
- Syracuse NY
Black- 1998 Trans Am
If that MAF is actually bad, that car will very noticably run like $hit. Take it of and spray it down, just dont touch the tiny wires inside
10-17-2009, 11:48 AM #9
yeah ive cleaned it twice now, and yes the car runs like crap its putters out an dies sometimes it chokes up on accelration, and my gas milage has been reduced by quite a bit, but i checked out some salvage yards for one there wantin a bill for one and a new one from the parts store is 170 so i figure might as well get the new one thats reliable instead of one thats set on a car for who knows how long and who knows what condition it is in.
10-17-2009, 01:18 PM #10
10-18-2009, 12:06 AM #11We'll be back...
- THE SWAMP
Did you clean it with a nonresidue electronics cleaner? If you used an electronics cleaner that leaves a residue, it will not do any good as the residue will prevent the sensor from functioning properly.
10-18-2009, 02:58 AM #12
I agree.
You don't need a scanner to check the MAF. You can check voltage on it or resistance.
http://forum.doityourself.com/archiv.../t-167282.html
My WS6 replacement
By 01WS6475hp in forum Member's RidesReplies: 12Last Post: 03-08-2010, 03:27 PM -
Question: Replacement Key
By KJax2010 in forum GTOReplies: 10Last Post: 06-21-2009, 02:18 PM -
TPS Replacement
By shlby123 in forum General HelpReplies: 2Last Post: 06-09-2007, 04:08 PM -
Air bag replacement help
By 9999 in forum General HelpReplies: 1Last Post: 05-06-2007, 12:23 PM -
t-56 replacement
By SuperSport02 in forum DrivetrainReplies: 5Last Post: 05-04-2006, 08:15 AM
