Thread: upcoming H/C build
10-12-2009, 06:56 PM #1Junior Member
- Jan 2008
- Ontario, Canada
White- 1999 Trans am Convertible
upcoming H/C build
American Racing Headers w/ Cats
SSHT Cam
Plugs and Wires
Trickflow 215cc Heads
JP Double Roller Timing Chain
Under Drive Pulley
Pushrods
Yella Terra 1.7 Rocker Arms
Port and Polish Throttle Body
Port and Polish Oil Pump
New Belts for UD Pulley
Front Crank Seal
Precision Single Disc Converter
Any thoughts/ comments?
I currently have 3:23 gear (thinking of leaving that for now). Looking at some wheel/tire upgrades as well.
10-12-2009, 08:06 PM #2
What intake are you going with? Who makes that cam, and what are the specs? As cast heads or ported?
10-13-2009, 04:04 AM #3Junior Member
- Jan 2008
- Ontario, Canada
The cam is a 228/232 .600 111 LSA from New Era Performance (they have it made by someone else).
10-13-2009, 04:05 AM #4Junior Member
- Jan 2008
- Ontario, Canada
I have an LS6 intake. Not sure about the "cast or ported" part of your question.
10-13-2009, 05:12 AM #5
10-13-2009, 05:24 AM #6Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
Also, what head gaskets are you going with?
Have you thought about the other gaskets you will need? Bolts?
When I did my H/C/I Swap, I used this....had everything I needed, and I would suggest ARP bolts. I know you're not PLANNING on taking stuff back off, but you never know.
Also, when I did my swap, my Double Roller Timing Chain (Rollmaster) prevented my UD Pulley from going all the way on. I had to get .300" machined off in order to make it fit. Cost me about $10 at a local machine shop.
Last thing...be careful when putting the oil pickup tube back into the oil pump. Two common problems could happen...one, you could put it in crooked, resulting you having no oil pressure on startup and you would have to take the front off again to fix it. Second, don't drop the bolt into the oil pan...I did it twice and have to go fishing with a magnet.
Last Last thing...grab some red locktite from Autozone and use it on everybolt...prevents them from vibrating out.
10-14-2009, 11:28 AM #7
Something to be wary of is some people have cracked there yella terra's
X2 on the heads as cast, chamber size?
issues upcoming
By 0rion in forum General HelpReplies: 6Last Post: 03-21-2012, 09:12 PM -
Upcoming Mods
By ChvyCruzen in forum Camaro / SSReplies: 6Last Post: 06-10-2010, 09:13 AM -
upcoming race, part 2 vs the sti
By blue02Z in forum Kill StoriesReplies: 16Last Post: 11-21-2008, 07:50 AM -
Upcoming races: what do you think?
By GottaHaveLS1 in forum Kill StoriesReplies: 3Last Post: 05-11-2008, 08:18 PM -
Upcoming Race...
By JwMonE99 in forum Kill StoriesReplies: 40Last Post: 01-23-2008, 03:25 PM
