Page 1 of 3 123 LastLast
Results 1 to 20 of 51
    Member devil6rr's Avatar
    NJ
    SOM / NBM
    2002 Pro Z28/2001 TurboTA
    So i finally go to the track and....(pics)
    This happend
    Any One know of any upgraded driveshats?
    or was this a freak thing?
    Launched at 3800
    Tires: Nitto 555R's 22 psi
    Temp: 66 degrees
    Small burnout first
    NJ
    SOM / NBM
    NJ
    SOM / NBM
    NJ
    SOM / NBM
    anyone?
    Junior Member Ryans_Pewter_SS's Avatar
    Aug 2008
    North Carolina
    2002 Camaro SS
    I done the same to mine, i bought a PST to replace mine with.
    Holy carnage!
    I noticed that your u-joints do not extend the full width of the yoke's saddle. I had to replace my rear u-joint earlier this year and it looks exactly like yours. Since you snapped the shaft and not the driveshaft yoke, I guess I won't worry about it.
    NJ
    SOM / NBM
    Quote Originally Posted by Ryans_Pewter_SS View Post
    PST?? got a link?
    thanks
    Junior Member Kamesense's Avatar
    NY
    99 Z28
    Aug 2008
    North Carolina
    2002 Camaro SS
    Got mine from exotic performance
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Go aluminum, and go PST. Rated at 1200 HP, and a lifetime warranty I believe. I have no reason to not like mine yet. Your lucky that's all the damage that happened, could have been worse. If you plan on putting a slick tire on the car, I would opt for the extra 120 bucks for the DS safety loop.
    NJ
    SOM / NBM
    Thanks Everyone i just ordered the 3.5 PST from EPP
    Marylandistan
    2001 Trans Am (sold)
    Been there done that.
    Personally I'd rather have a 3' steel/chromoly than the 3.5' aluminum one but the PST should be fine. I recomend the Strange 3' chromoly.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    I also got the PST from EPP.
    As far as the DS SL, which one did you get? Are there any that bolt on without dropping the DS?
    Member camaross1's Avatar
    Aug 2009
    chesapeake,VA.
    2002 camaro ss
    Spohn performance has all upgrades for the f body, you need there 3 inch chrome moly 4130n with1350 yoke has.083 wall thk
    NJ
    SOM / NBM
    My PST shaft should be here monday cant wait to get to the track again b4 it shuts down! should that have happend from a 3800 launch ! LOL 315 Nitto 555r's and small burn out ?
    Aug 2009
    chesapeake,VA.
    2002 camaro ss
    your drive shaft and devil 6 driveshaft broke,twisted in the same spot ., thats interesting gm weak spot i guess
    NJ
    SOM / NBM
    good call thats interesting...
    Florida
    1999 TA WS.6
    Yes, there is a DS SL that is a two piece. It does not require you to drop the DS, Its been so long since looking, I forgot the brand. A quick search on the boards will show it.
    ls1 powered seabee sutie's Avatar
    oxnard, ca.
    red and black
    1999 Formula/WS6
    lakewood has a two piece loop thats also bolt in. thats what i have and was very easy to install.
    NJ
    SOM / NBM
    Yep got it, just need to install
  1. Finally back to the track
    By GTO1_OHIO in forum GTO
    Last Post: 02-08-2013, 05:43 PM
  2. finally made it to a track!
    By LSCyaL8R in forum Almost Anything Goes
    Last Post: 04-26-2010, 01:53 PM
  3. finally went to the track
    By craig02ta in forum Drag Racing
    Last Post: 06-24-2007, 07:18 PM
  4. Finally took my Cobra to the track..
    By Cobra 2004 in forum Drag Racing
    Last Post: 06-01-2007, 04:04 AM
  5. Track DAY FINALLY Set!
    By rodent in forum Rocky Mountain Members
    Last Post: 05-24-2007, 10:44 PM
