10-11-2009, 04:40 PM #1Junior Member
- Oct 2005
- houston, tx
Black- 1999 Camaro SS
Replaced, belt tensioner, still noises?!?!
okay so took it in complained of squeaking when i was getting other things fixed, thinking it would be some simple adjustment. they replaced the belt tensioner assembly for the ac. still squeaking and took it in again, they replaced ac control head and ac belt tensioner and belt without asking and when i looked at reciept to pick up car i said you already replaced this. They said well first they replaced it for the main belt assmebly and now they replaced it for this different assembly and said they fixed the problem. Good for two days no noises, now it's still squeaking (louder) but squeaks more the faster the rpm's go, something that it never did before. Wish i never mentioned it in the first place and paid all this fucking money to have it worse. Anyone know the problem might be???
10-11-2009, 04:51 PM #2Senior Member
- Apr 2008
- Madison, WI
So sounds like you have 2 new tensioners (one main and one AC) and a new AC belt, correct? So, if all the pulleys looks clean (no oil, coolant, or other gooey/slimely mess) and there isn't any pulley misalignment, then I suggest you replace both belts with a gatorback belt.
10-11-2009, 06:35 PM #3
10-11-2009, 06:56 PM #4
X3 -- Some belts just tend to be noisy. Had a set of Kelly belts on my Talon a few years back and they were awful, especially in damp weather. Quick test is to shoot the belt with a little belt dressing. If the squeak disappears, but returns after a few days, then you just need to try a different brand of belt. Gatorbacks are a little pricey, but I have never had any issues or noise with a set.
10-11-2009, 10:24 PM #5Single Malt
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
Pull the main belt & spin the waterpump pully.
Might have a bearing going out in it.
10-13-2009, 08:04 AM #6
The Gator Back belts are actually thinner than their stock counterpart, I would use the stock replacement for the extra strength.
SteveC
10-13-2009, 06:51 PM #7
oil catch can vs. katech belt tensioner
By godless-phoenix in forum Firebird / WS6Replies: 11Last Post: 06-02-2010, 06:42 PM -
Belt tensioner?
By Sas in forum External EngineReplies: 2Last Post: 04-08-2010, 07:24 PM -
A/C belt tensioner pulley and idler
By 1st TA in forum External EngineReplies: 12Last Post: 01-23-2008, 01:58 PM -
Belt Tensioner question.
By Chad97z in forum LT1Replies: 1Last Post: 09-29-2007, 01:41 PM -
WTB: Belt tensioner
By MagicMan in forum Parts Wanted / TradeReplies: 1Last Post: 09-05-2006, 01:33 PM
