Thread: bad clutch test
10-07-2009, 07:44 AM #1
bad clutch test
So ive posted a thread before asking how to tell if your clutch is bad.. somone told me put it in high gear (5th or 6th) and try to take off around 2000rpms
so i tried it and the car stalled (which meant clutch was ok)that was a couple months ago.
now i tried it again about 10 mins ago and i took off very slowly and i heard a chattering noise..
so my question is is the chattering noise another problem on top of needed a new clutch or do i just change the clutch and it should be fine?
please reply!2001 Camaro SS M6 SLP LMII, Lid
1987 iroc-z RIP 5.7 TPI Full exhaust, lingenfelter intake runners (gone but not forgotten)
1991 bmw 325i DD
10-07-2009, 08:25 AM #2
Doing that will kill a good clutch
The chattering is due to the clutch getting hot,,,and probably has now caused hot spots on the flywheel and pressure plate.
A better way to check for a slipping clutch would be to have the car in high gear at a slow speed and mash the throttle.
Say 4th or 5th gear at about 1500 rpms. If the clutch holds there probably isn't any worries. If the engines revs and car doesn't accelerate, there might be a problem
Most worn clutches slip in this mannor, because they have the least amount of gear multipication to move the car along.
10-07-2009, 08:34 AM #3
i think im just gonna replace it lol it engages way at the top and it's had the stock clutch for 67k miles now... its gonna have to be done sooner or later... but ill try that test too thanks. anybody else got advice or words of wisdom?
10-08-2009, 08:05 PM #4
you are testing it incorrectly... find a descent hill, approach it at about 60MPH or so in 6th gear. while going up the hill, smash the gas and watch the RPMs. If they shoot up quickly and you gain no speed really then your clutch is damn near toast. As stated before, do not try to take off in 6th gear from a dead stop.
Doing this test on a hill around 60MPH in 6th gear is the best test you can do on a clutch. w/out tearing everything apart to actually look at it.Last edited by TACE02; 10-08-2009 at 08:08 PM.
OSA Fluid Test - Vehicular Blood Test
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 01-24-2014, 05:50 PM -
The Movie Test.. A test that figures out your favorite movie
By ibanez7 in forum Almost Anything GoesReplies: 4Last Post: 04-25-2011, 05:57 PM -
Had Clutch slave cyl, clutch master cyl, and Clutch kit installed now I got problems
By 7camaro7 in forum Manual TransmissionReplies: 21Last Post: 12-13-2007, 07:41 PM -
z06 clutch for sale, pressure plate clutch disk and flywheel
By themack56 in forum Parts For Sale / TradeReplies: 2Last Post: 07-06-2006, 07:15 PM
