Results 1 to 10 of 10
Thread: oil breather ?
10-06-2009, 04:28 PM #1
oil breather ?
idk how many of you subcribe to high performace pontiac mag but this last issue they had a formula. he had a breather where his oil cap goes. does it really do anything, if not i guess it would be a cool apperance mod.
10-06-2009, 05:28 PM #2
I removed my PVC lines and I use a breather like that. One of my friends does the same thing.
10-06-2009, 05:37 PM #3James Bond
- Aug 2007
- Texas
so you need either PCV or a breather?
10-06-2009, 05:46 PM #4
Lots of info on this subject.
http://www.ls1.com/forums/showthread.php?t=81389
10-06-2009, 07:13 PM #5
Well there's a shit load of information on this, i simply asked Sarge and he said i'll be ok.
You can read information about this for days...i just gave up and asked Sarge
I went half of last summer with just a breather and this whole summer. Everything is ok so far...
10-10-2009, 08:11 AM #6Junior Member
- Kentucky
S O M- 2002 Camaro SS
When you put a breather on the valve cover you are venting the engine to atmosphere. Defeats the purpose of the pcv closed system. There are lots of good arguments against this. Search & read.
03-07-2010, 07:40 PM #7Junior Member
- Jan 2010
- Alabama
Yellow- 2002 Trans Am CETA
I've got a question on this subject. I am replacing the pcv valve and some of the hose because it has rotted through. Should I go with a catch can or breather cap. Reason I ask is because right now it is spraying oil from somewhere under the hood in that area and my dipstick is rusting like crazy. I know some of you say that a breather cap eliminates the need for a pcv valve. But will it be OK to have both?
03-08-2010, 03:27 AM #8Senior Member
- Apr 2008
- Madison, WI
yes you can have both with a catch can.
03-08-2010, 08:29 PM #9Junior Member
- Jan 2010
- Alabama
I see most of these catch cans you guys have are about $100.00 from the WS6 store and Thunder Racing. Are there any that are less or is it worth the extra money for these? Because I really don't care what it looks like.
Let me get this straight, I am running a stock motor, with a new pcv valve. If I get a catch can, should I need an oil breather cap too?
03-09-2010, 03:11 AM #10Senior Member
- Apr 2008
- Madison, WI
you don't need a breather but its a little better setup with one. At WOT there is more blowby and more crankcase pressure. Crankcase pressure creates resistance for the pistons to move up and down. on the Factory setup, that pressure get vented through the PCV valve/line into the intake. It also get vented into the TB through the other PCV hose. With that vented pressure goes oil mist which gums up your TB, Intake, and valves. The Catch can catches that mist and a breather vents to the atmosphere instead of back into your TB
Question: breather cap
By JayTA98 in forum General HelpReplies: 26Last Post: 05-19-2011, 08:15 PM -
catch can or breather?
By jmatt07 in forum General HelpReplies: 3Last Post: 05-11-2009, 01:51 PM -
Breather
By tingo99 in forum External EngineReplies: 11Last Post: 07-26-2008, 08:21 PM -
Re-Breather - Will the PCM code?
By The Silver Goat in forum GTOReplies: 6Last Post: 03-24-2008, 04:52 AM -
FRC, WG, Oil Breather
By MECHAM in forum Parts For Sale / TradeReplies: 0Last Post: 11-06-2007, 07:22 PM
