Results 1 to 20 of 29
    Feb 2008
    The Netherlands
    Dark Blue
    1999 Camaro Z28
    6 speed auto in 4th Gen?
    I was wondering:
    what will it take to swap my 4 speed auto for a modern 6 speed, like the 6L80?
    Can it be done?
    Should I or should I not want this?
    Mg
    mercersburg pa
    hugger orange
    2004
    I've wondered tge same thing about my 04 GTO.
    I know in the hptuners program there are some settings for 5th and 6th gear
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Mechanically I can't imagine that the motor side stuff would be all that different because it is an LSX motor it comes on. Only thing you may need is a different controller, mod the trans braket, resize the drive shaft and maybe change the input yoke. The TC, flex and pump shaft length should be spot on.
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    They do sell a kit from a corvette. Do not know the name of the company but it can be done.
    Feb 2008
    The Netherlands
    Dark Blue
    1999 Camaro Z28
    thanks so far, more info is welcome!
    What would it mean performance-wise (accelleration, top speed) and in terms of fuel consumption?
    Bay Area
    my highbeams
    Not really sure, all I know is there optional 2.73 gear would make our stock 3.23 a little faster. I would have to imagine better gearing but I am going to have to look that info up.
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by matthijsgrit View Post
    if I am correct the 6 speed gives you a steeper 1st gear, slightly closer gear ratio, so you get to keep the motor at peak power better and turn lower rpms in 6th
    a6 ratio's
    (1st) 4.484
    (2nd) 2.872
    (3rd) 1.842
    (4th) 1.414
    (5th) 1.000
    (6th) 0.742
    (reverse)2.88
    a4 ratio's
    (1st) 3.06
    (2nd)1.63
    (3rd) 1.00
    (4th) 0.70
    (reverse) 2.29
    Junior Member Lanaue's Avatar
    Oct 2009
    Parkville MD.
    Blue
    1999 Z28 SS
    I was looking into doing the same to my 3rd gen Z28. Just give them about 6-8 months and someone will have a kit.You know it's been asked.
    Bay Area
    my highbeams
    Quote Originally Posted by Lanaue View Post
    There is a kit it even comes with those paddle shifters-I just don't know the name.
    mercersburg pa
    hugger orange
    2004
    with the 4.484 1st gear, you wouldn't need 411's would you lol
    Bay Area
    my highbeams
    Quote Originally Posted by mark21742 View Post
    You wouldn't want 3.73's
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Well.... I have a 2007 tundra and it has a 5 speed auto and one of the things that caught my attention was the 4.10 rear gear and the 3.8X first gear. It is wild but works out great any more gear and it would be a waist but that is just right for the power of the 4.7 motor and the wieght of the truck for what it needs to do. I would say your right about the 4.10's but depending on the power you are making 3.73's may be right on the money. If you make more power I would say 3.23 or 3.50 or so would fit better but then it still depends on engine setup. boost motors like less gear because they have a chance to build full boost before a shift point. Cool Idea though
    What I do? SHines-IT's Avatar
    Jun 2009
    FL, USA
    2011 Prius
    I saw this somewhere to, it's saved on an old computer, but I got mad and broke it.
    Bay Area
    my highbeams
    Quote Originally Posted by SHines-IT View Post
    Member 346ci's Avatar
    AK
    1998 Z-28
    I think the swap would be quit involved as the 6L80 has an internal TCM in the valve body controlling it. Where as the 4th gens has a PCM controlling the trans. I dont think you could tie in the 6L80's TCM with a 4th gen PCM, much less there being a way to tune it.
    Unless there is some aftermarket conversion kit I am unaware of, I think you would need an ECM and harness that is compatible with the 6l80's TCM, such as one from an LS3 that is designed to operate with that trans. I could be wrong, but I think it may be more headache and cost than it's worth.
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by 346ci View Post
    I know there are companies that offer tranny controllers for the 4l60e in older cars for $400-$600, I'm sure they have them for the 6 speed too
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Google a company called Speartech
    Madison, WI
    2001 Silverado Z71
    I did some research and it seems that its most common to get a engine control module that is compatible with the existing trans module built into the 6L80e. Sounds like the 6L80e's shift setup and controls are very complex.
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Sorry cutlass I have read that statement and for some reason I just cant figure it out. Are you saying that you can get a Factory ECM that can control the 6L80E and the Ls1's in an F body? or that you need an after market companies controller for both engine and trans? or did I just flat out have a brain fart and misunderstand that all together?
    I may be loosing it
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by JaycenK View Post
    I may be loosing it
    stock computer out of a car that came with an a6 would work.
    you'd probably need the matching wiring harness too
  1. Question: 4th Gen with a new Gen auto 6 speed
    By 01SsRacing in forum Drivetrain
    Last Post: 07-06-2012, 03:51 PM
  2. Question: 6 Speed Auto
    By wickedbeast in forum Automatic Transmission
    Last Post: 05-04-2011, 05:45 PM
  3. 6 Speed Auto's
    By Intrepidman in forum Automatic Transmission
    Last Post: 12-07-2010, 08:20 AM
  4. My Auto for your 6 speed
    By eddielb in forum Parts For Sale / Trade
    Last Post: 02-06-2007, 12:08 PM
  5. auto vs 6-speed
    By mystic-z in forum Camaro / SS
    Last Post: 11-19-2006, 05:56 PM
